front wheel drive, front inner tire wear
B13 SE-R
i've only had these tires on the front for about three or four months, but the wire banding in the tires are already showing on the inner tread of the tire.
i've heard it could be the ball joints, which according to my haynes manual are in the control arms and it recommends buying all new control arms, but i'm hoping it's something less expensive.
what are the causes of the camber that would result in inner tire wear?
B13 SE-R
Re: front wheel drive, front inner tire wear
sorry, the suspension's stock, it's never been wrecked. i've only had it for about six months but i haven't had it aligned.
baller/dickbutt#69
i would take and have it aligned...it probably has bad toe.
which means the tires are either pointed towards each other or away from each other and not where they should be...
i believe if the are pointed out then it will wear the inner out
CPL Us Army
If the ball joints are shot could be a reason. Isn't if the tires are pointing toward or away from each other camber though? meanin' inside of the tires are showing camber wear?
baller/dickbutt#69
pointing towards and apart is toe in and out
camber is when the top of the tire leans in...like when lowered...hence the reason for camber kits.
This. Check for excessive wear.
