engine code????
Old Mar 26, 2003 | 09:18 AM
envyno1's Avatar
envyno1 is an unknown quantity at this point
Default engine code????
i was wondering the engine code for the zc motor(2nd gen.)cause i was wondering if i can hook up my dx tranny to it and plug my stock ecu to it.
Old Mar 27, 2003 | 06:15 AM
CHAHONDA's Avatar
corona connessuer
a ZC is considered to be a d series engine. your tranny will bolt to it. the ecm should work also, really depends on what model your car is?
Old Mar 27, 2003 | 09:05 AM
91 Hatch's Avatar
SSSSSVT
91 Hatch 91 Hatch 91 Hatch 91 Hatch 91 Hatch 91 Hatch 91 Hatch 91 Hatch 91 Hatch 91 Hatch 91 Hatch
ZC is like a 86-89 intgra any d series transmission will bolt to it. You have a dx that means you have the dual point injection, so you will need to use another computer like an Si. 2ND Gen integras have B18A's in them. You will also need to get your car rewireing for the motor. (if you have a 88-91 Hatch)
Old Mar 28, 2003 | 09:22 PM
envyno1's Avatar
its going into a 93 coupe, so what well i need to complete the swap.
Old Mar 29, 2003 | 04:22 AM
CHAHONDA's Avatar
corona connessuer
i have never put a zc in a 5th gen civic. you may need a lh (drivers) side motor mount???? you will have to change some plugs around to get the distributor to function properly. the stock ecm should work. you could also use a 94-95 teg ls ecu also if need be. if it were me i would just use a 94-95 teg ls swap instead, more power and less complications!!!!
h22_Lude
Dec 29, 2008 07:25 PM
bLu92bUbbLe
Jun 12, 2006 06:07 PM
89crxdude757
May 25, 2005 07:34 AM
sargeek1975
Oct 24, 2003 06:32 AM
zexpwrd4door
Jun 17, 2003 03:48 PM
