Engine Building Shops....
Old Sep 20, 2004 | 12:29 PM
reddevil94's Avatar
Droppin E-Thugs!!!!!
reddevil94 reddevil94 reddevil94 reddevil94 reddevil94 reddevil94 reddevil94 reddevil94 reddevil94 reddevil94 reddevil94
Thumbs up Engine Building Shops....
Where can I have a good builder build my ls/vtec block, just need the crank on and gsr girdle put on, using stock caps or using the gsr caps. Bore and hone the cylinders. I can do the rest of the work just need the honing and boring of the block and need to get a yes or no of the installation of the girdle, I know that machining will have to be a must, just wonderin why it cost so much to have it done. I have done a lot of research and tried explaining to some people about the ideas, that some people have used, and worked on ls/vtec buildups. Your help will be appreciated.....thanks....
Old Sep 20, 2004 | 12:42 PM
Keepin it Klean's Avatar
Clean Freak.
Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean Keepin it Klean
Default Re: Engine Building Shops....
abacus racing does great machine work they have a lot experience with honda motors...talk to chuck there he can help you out...
http://www.abacusracing.com/
Old Sep 20, 2004 | 01:19 PM
reddevil94's Avatar
I am just trying to figure who can put a gsr girdle on a ls integra bottom end.....I have steps on how to due this, but I am seeing if there are any qood shops around that could do it. I have everything that I need to build my ls/vtec motor setup, just need a good builder that will assemble the bottom end for a decent price, I will install all the parts just need the crank in, with the girdle and rods and piston, bore and hone, I will install everything else myself.
Old Sep 21, 2004 | 12:52 PM
Post Whore's Avatar
Post Whore has disabled reputation
pm boosfed(Terry)..he has good prices
Old Oct 6, 2004 | 08:06 AM
reddevil94's Avatar
will try to pm boostfed......
Global688
Oct 16, 2006 03:22 PM
bakuryu06
Mar 17, 2006 09:06 AM
Babied 240
Jan 11, 2005 02:43 PM
TEC
Dec 7, 2003 09:51 AM
gen4H22A
Oct 3, 2003 06:34 PM
