Em1 Issues
Old Jan 27, 2007 | 12:29 PM
  #21
Tmac85's Avatar
Busa Cap
Tmac85 is on a distinguished road
Default Re: Em1 Issues
I appreciate that but the break in point has been passed, and I did the break in just right. Now ive replaced the 02 sensors and the check engine light went off. Now im stuck between a rock and a hard place trying to install the mfer wheel bearing.
Old Jan 28, 2007 | 02:16 PM
  #22
Tmac85's Avatar
Busa Cap
Fixed all problems except Vtec, no engine light is on idk wtf is going on.....
Old Jan 28, 2007 | 05:12 PM
  #23
SlowLS's Avatar
Sumospeed #O.G.
pm me if you need the wheelbearing done still.
Old Jan 28, 2007 | 05:17 PM
  #24
Vern's Avatar
turbo on 2 wheels
Vern Vern Vern Vern Vern Vern Vern Vern Vern Vern Vern
wheel bearing is done, just need vtec to work....
Old Jan 28, 2007 | 05:32 PM
  #25
Tmac85's Avatar
Busa Cap
I could of used you friday night.....
Old Jan 29, 2007 | 10:46 AM
  #26
kyle h.'s Avatar
fraggle rock
kyle h. will become famous soon enough
hows the oil pressure?
Old Jan 29, 2007 | 05:45 PM
  #27
Tmac85's Avatar
Busa Cap
Now the engine light is back on, and its throwing code 45, which is its either running to rich or to lean. What are some symptons of this?
Old Jan 29, 2007 | 06:01 PM
  #28
esohsee's Avatar
I'm worse drugged
esohsee has disabled reputation
what ecu you using? pull your plugs and what do they look like white, black, brown, and check if there are speckles around it? what kind of o2 sensor did you get? was it new?
Old Jan 29, 2007 | 06:04 PM
  #29
Tmac85's Avatar
Busa Cap
The plugs are pitch black, i got one used o2 and one universal o2, the ecu i have is a stock si which i think is p2t, im not sure
Old Jan 29, 2007 | 08:33 PM
  #30
esohsee's Avatar
I'm worse drugged
running rich. check if your oil smells like gas. get another o2 sensor i hear nothing but bad things with universal o2 sensors. i would get a new ngk.
