dohc zc all motor question
besides the list below, and besides boring out the motor, what else could I do keeping it all motor?
-header, underdrive pulleys, cold air intake, msd ignition box, throttle body, intake manifold, thinner headgasket for higher compression, exhaust,
adjustable cam gears and tune
Re: dohc zc all motor question
A lot of flow work for the head (it needs it), a multi-angle valve job, cam, higher compression pistons, tolerance blueprinting, really any other engine mods that don't require adding forced induction...
Do you have strange concept that all-motor performance has to do with not cracking into the stock bottom end assembly?
no! I'd love to run high compression pistons but I can't find any that don't require machine shop work to bore out the motor. I'd love to be able to get some stock sized high comp pistons to throw in there. i think stock for the zc is 75mm if i'm not mistaken right?
isnt the dohc zc the highest hp rated D series?
also - are there high comp pistons for it that don't require boring the engine?
HONDA ENGINE CODES & HORSE POWER GUIDE
Engine Displacement Description Car Hp
EW4 1.4L & 1.5L SOHC PGM-Fi 84-87 Civic 60-92hp
D15B(?) 1.5L SOHC Non-VTEC 88-95 Civic 62-102hp
D16A1 1.6L L DOHC 86-89 Integra 86/87 113hp 88/89 118hp
D16A6 1.6L SOHC 88-91 Civic Si/ CRX Si 108hp
ZC JDM equivalent of D16A1 130hp
D16Z6 1.6L SOHC VTEC 92-95 Civic EX/Si 125hp
D16Y5 1.6L SOHC VTEC-E 96-00 Civic HX 115hp
D16Y7 1.6L SOHC non-VTEC 96+ Civic CX/DX/LX 106hp
D16Y8 1.6L SOHC VTEC 96+ Civic EX 127hp
