Diagnose my problem on m car please
my subaru died on me today. please help me diagnose the problem.
Vehicle: 97 legacy outback
started my car this morning and vehicle made some funny noises. drove around a bit and still making funny noise. don't know how to describe the noise. just more noise from under my hood.
when I tried to cut my car off, sounded like the car was trying to start back up. I turned key in off position and car was just cranking away. kept on cranking till I turned my key to on position. then car would start back up.
I tried to turn key in off position again and the car kept cranking. so I turned the key to on position and car started.
the car was already on, but I couldn't cut it off because everytime I would try to cut it off, the car would start cranking.
enentually, the car died.
I tried starting it up and nothing
sounds like it was an electrical problem with ignition or starter. so I tried pulling the ignition fuse when having the problem and nothing.
when the car died, tons of white smoke from under my hood.
I think my starter was having problems and eventually my starter seized and burnt up. does this sound right?
The starter relay is stuck closed.
The smoke could be the starter, it could also be the starter wires that overheated and started burning the insulation off. Next time unhook the battery ASAP.
Originally Posted by japspec4g63
a starter seizing up and burning out would cause a lot of white smoke?
Originally Posted by FlodaSE-R
It's not JDM enough. Add some air freshners.
