D16Y8 Problem
Old Mar 24, 2004 | 06:26 PM
In the Works's Avatar
In the Works has disabled reputation
Default Re: D16Y8 Problem
Ok Set the VAFC up to monitor VTEC enagaement. Noticed that every once in a while VTEC does not even engage. And that is one of my cel. i think the other at low rpm is just running super rich. Could my vtec soleniod be going out. Also Anyone know a good place for dyno tuning. Need to get this thing fine tuned after adding all this stuff. A good shop to go to and how much they charge if possible
Old Mar 25, 2004 | 05:41 AM
CHAHONDA's Avatar
corona connessuer
ABACUS
Old Mar 25, 2004 | 05:42 AM
CHAHONDA's Avatar
corona connessuer
you bringing the mirage out here today?
Old Mar 25, 2004 | 07:59 AM
Mo than likely But you won't know cause its a MIRAGE. You'll think your seeing it but it won't really be there
Old Mar 26, 2004 | 03:52 AM
CHAHONDA's Avatar
corona connessuer
ok how about bringing it today??
Old Mar 26, 2004 | 04:13 AM
as soon as they get the trans out i am gonna pick it up and head over. Kinda pointless to drive it over there and add it to your growing lot when i don't have the part to fix it
Old Apr 5, 2004 | 10:08 PM
Zulu's Avatar
BITCHES COME!!
Zulu has disabled reputation
Did you install the VAFC and the Skunk2 Chip at the same time? There could be a conflict between the two and that could cause your CEL to come on. Have you tried Zeroing all of your VAFC settings yet? You might want to check out http://www.d-series.org as well, tons of very knowledgeable people on there.
Old Apr 6, 2004 | 03:52 AM
Finally. I was begininning to think i was a leper or somethin. yeah i did install them at the same time. I will check out that site too.
Thanks Zulu
Old Apr 6, 2004 | 10:16 AM
Zulu's Avatar
BITCHES COME!!
No Problem If you zero all of your VAFC settings and you still get a CEL try disabling your chip. There is a jumper in your ECU you can cut, J1 I believe but i need to confirm that. If you cut it your Skunk2 chip will no longer work but you might lose the CEL. After you cut it, you can try using your VAFC again. If i had to put money on one of the them I would say that your skunk2 chip screwing up the whole works. Also, if you still get a CEL for your VTEC then you could have a bad selenoid. Hope that helps.
Old Apr 6, 2004 | 03:27 PM
Yeah i noticed that i would say about 80% of the time the vtec activates and 20% it doesn't.
