!cr-vtec!
Old Aug 8, 2005 | 02:33 PM
TiSoY's Avatar
Pay It Forward...
TiSoY is an unknown quantity at this point
Default Re: !cr-vtec!
Originally Posted by SlowLS
And as far as tranny goes. Use a JDM YS-1 tranny w/ LSD. Or if it just going to be a track car, the J1 has super close gear ratios, but no LSD...
Actually, some JDM B16 J1 trannies did come with optional LSD, but are hard to come by. Personally, I would go with a Type R tranny (JDM or USDM, since they're both LSD) if you have the money to spend, but you will need the hydraulic adapter from HASport. Good luck!
Old Aug 9, 2005 | 12:23 PM
10till4Z's Avatar
GAME OVER
10till4Z has disabled reputation
thanks guy... looks like ive got alot of work ahead of me.
Old Aug 14, 2005 | 10:19 AM
blkmjk's Avatar
the"V8nightmare"
blkmjk is an unknown quantity at this point
Originally Posted by b16a2
The B20vtec is an excellent choice for an NA setup. It makes a decent amount of torque hence the bigger displacement but doesn't sacrifice top end power. There are alot of rumors going around saying they are unreliable but its all in the build quality..make sure you do it right the first time. B20 sleeves are thinner than other b series blocks because it is essentially just bored over. Sleeving the block from the start is a good idea but not needed, its just an added security precaution so you wont have to worry about cracking a sleeve one day. Yes you can still run high comp. pistons with an unsleeved block BUT I wouldn’t go around rev happy. Even a bone stock block will hold up as long as you’re not being an idiot. I myself ran 11.1 pistons in my unsleeved block for a year with no problems whatsoever. I also had a ported head with cams, springs, retainers. I was making 217whp/ 158 tq on hondata running 12's all day in a full body integra. I could go on for days but I had a long night..Let me know if you have any further questions, I’ll be more then happy to assist you
well Im using a buddies account to reply. Im the guy with the CRvtec in the crx. I dont know who told you that b20 sleeves were thin but you are highly mistaken. and 2nd
"I myself ran 11.1 pistons in my unsleeved block for a year with no problems whatsoever. I also had a ported head with cams, springs, retainers. I was making 217whp/ 158 tq on hondata running 12's all day in a full body integra"
you must have much more then what you listed to make those numbers. I was wondering what setup was. Tranny, bottem end build, suspension ect. and 3rd, no top end power...what? Im not going to agree with you on that one either. Anyone remember the 160mph run? I think you might want to do some research.
Old Aug 16, 2005 | 01:08 PM
blkmjk's Avatar
the"V8nightmare"
damn george get im... oh this is the buddy the crx was georges.
b20 vtec is a beast and if its going in a crx it will haul ...
jack the comp and through in some great cams and u will be fine. i think george was making 232hp and 175ish torque in his set up 12:1 je pistons ,rods ,and a balanced bottom end. jun cams stage three all jun valvetrain and a type r head . all george had was a block gaurd other than that stock sleeves were functional.oh and plenty of topend 160mph and its on tape !!!for the disbelivers.
Old Aug 17, 2005 | 05:29 PM
FastCrxVaWLude's Avatar
FastCrxVaWLude is an unknown quantity at this point
hey whats up drew. i wish i had those numbers. 227whp and 147wtq. has 12.5.1 pistons but with the head gasket made it about 12.1. i thought u might like this pic. this is when u brought my car to amost 10grand on the tach. remember, hehehe. pm sent on AIM
Old Aug 25, 2005 | 03:55 PM
blkmjk's Avatar
the"V8nightmare"
oh yeah its a shame we never reved it that hard on the street.... hehehheheh !!!!!but then there was that time when ur tach was f.u.b.a.r. and we were raping those bikes except for the busa...
Old Aug 26, 2005 | 02:06 PM
b16a2's Avatar
b16a2 has disabled reputation
HAHA you above all people should know what I meant by the sleeves being thin. Meaning the distance in between each cylinder is smaller. Like I stated before it is essentially a bored b18 block. Of course the actual composition of the inside of the sleeve is not thinner that would make absolutely no sense.
Sorry my engine build was kind of vague, I listed the jist of my setup not details. I was running stock bore JE pistons 11.1 compression, With a fully worked b16 head, Skunk2 gears, stage 2 cams, springs, retainers, valves, P&P, 5 angle valve job, IM, Port matched TB, RC 550's, Walboro 255,
Full 2.65in exhaust, toda header. I was also running a ctr tranny .If you think this setup fully tuned could not pull 12's and 217whp/158 you must be smoking crack.
Also nowhere in my post did I mention my setup had no top end power. I specifically stated the b20vtec has plenty low end power and DOES NOT sacrifice top end.
Thank you.
Old Aug 26, 2005 | 08:01 PM
Thank you.
Old Aug 28, 2005 | 06:43 AM
Yell88CRXsi's Avatar
Team Ultraspeed
All this talk about 2.0's makes me want to drop my new motor in now. But alas, I must wait until the new baby comes. So this will end up a winter project...damn.
gotboosthatch
Dec 18, 2008 03:55 PM
Woodpsuher50mm
Want to Buy / Trade ARCHIVE
Jun 1, 2008 06:34 PM
Tim-Tim
Jan 29, 2008 07:19 PM
