coolant into vaccum line need help
Old Jan 25, 2009 | 04:54 PM
  #21
Lord Humongous's Avatar
VaDriven Mayhem
Default Re: coolant into vaccum line need help
Originally Posted by nftuatn
take the plugs out and crank it over if it will until all the water is out....then take an air hose and blow into the cylinders to help dry it out....put some new plugs in it and see if it will start....if it does your damn lucky....if it doesnt then you need a motor or at minimum a set of rods/pistons...
Yep...
But I think you're fucked.
Good luck
Old Jan 25, 2009 | 04:55 PM
  #22
nftuatn's Avatar
baller/dickbutt#69
well he did say it cranks....so unless its bent rods or valves it may run
Old Jan 25, 2009 | 04:56 PM
  #23
dsmx17's Avatar
101011
dsmx17 dsmx17 dsmx17 dsmx17 dsmx17 dsmx17 dsmx17 dsmx17 dsmx17 dsmx17 dsmx17
Retards + cars never work out well. Maybe a screening process should be used when selling parts to people? for example: do you know the difference between a coolant hose and a Vacuum line if the answer is no, hit them with whatever part it is they came to buy, and skip away laughing.
Old Jan 25, 2009 | 04:58 PM
  #24
nftuatn's Avatar
baller/dickbutt#69
lol +rep
Old Jan 25, 2009 | 05:24 PM
  #25
Breezy's Avatar
Breezy is infamous around these partsBreezy is infamous around these partsBreezy is infamous around these partsBreezy is infamous around these partsBreezy is infamous around these partsBreezy is infamous around these partsBreezy is infamous around these partsBreezy is infamous around these partsBreezy is infamous around these partsBreezy is infamous around these partsBreezy is infamous around these parts
I don't know the difference between a coolant line and a vacuum line albeit I could probably figure it out. That is why I don't work on my cars I just take them to the shop.
This was a lol-maker tho!
Old Jan 25, 2009 | 06:13 PM
  #26
dXXX96civic's Avatar
make 7 UP yours
dXXX96civic has a reputation beyond reputedXXX96civic has a reputation beyond reputedXXX96civic has a reputation beyond reputedXXX96civic has a reputation beyond reputedXXX96civic has a reputation beyond reputedXXX96civic has a reputation beyond reputedXXX96civic has a reputation beyond reputedXXX96civic has a reputation beyond reputedXXX96civic has a reputation beyond reputedXXX96civic has a reputation beyond repute
I dont know where to start........
If I read correctly, you have gotten the car running again, just still mucking up the oil and making a mess on the plugs.... How many times have you changed the oil??? need to make sure you change it, buy a case of shitty walmart oil and flush out the head and drain it, clean or replace the plugs and leave them out a couple days in the garage so the engine can dry out. when you put the plugs back in and start it, have your buddy shove a coolant line up his azz just for good measure.... but seriously you need to flush the motor and air it out and leave it alone for a couple days so you dont make it worse. If you get it all together and get milky oil again, might as well sell it to your 'buddy' for way too much money, tell him its high performance and will make his go-ped fly
Old Jan 25, 2009 | 08:23 PM
  #27
philville's Avatar
philville philville philville philville philville philville philville philville philville philville philville
i lol'd
Old Jan 25, 2009 | 08:56 PM
  #28
ryanherington's Avatar
yaaat.
How did he manage to get them to go together and not realize he's trying to get two COMPLETELY DIFFERENT things to go together? FUCK. It's really not that hard. Honda didn't make shit that hard to reassemble. If it doesn't fit, it doesn't go there.
Old Jan 25, 2009 | 09:32 PM
  #29
it2qwk4u's Avatar
it2qwk4u has disabled reputation
no i have a supercharger. the lines are way diff. from the stock IM.
Old Jan 25, 2009 | 09:34 PM
  #30
yaaat.
Regardless, I don't see how he messed it up.
