Car shut off going down the road, what's the problem?
Old 08-19-2013, 07:37 PM
  #21
Digital Life
83Stang5.0's Avatar
Default Re: Car shut off going down the road, what's the problem?
Originally Posted by shags420
yea it had an external coil, i removed that and put a stock dizzy and coil on it..
This is your problem, you've done too much and given too little info. Out of all these things you've done, were they done before or after the car shut off driving? Which were done when? Is the car throwing any codes?
83Stang5.0 is offline
Old 08-19-2013, 07:38 PM
  #22
shags420's Avatar
shags420 has disabled reputation
and the comment wasn't even towards you, and way to profile some one, my nick name is shaggy and my birthday is April 20 and if you don't like wtf i said then fuck off. i don't need your advice any ways. sorry if he's you butt buddy
shags420 is offline
Old 08-19-2013, 07:44 PM
  #23
shags420's Avatar
i just bought the car i never red lined it drove it shitty etc. i was going down the road and it bogged out and wouldn't start, i called a mechanic and he said that the head i have ( b16a2) ( '00 civic si ) is famous for its igniter going out so i just replaced the whole dizzy, canceled out the external coil and put a stock cap, with a stock coil which was already in the dizzy.. new wires and plugs... all to do with ignition that i know of..
shags420 is offline
Old 08-19-2013, 08:20 PM
  #24
Digital Life
83Stang5.0's Avatar
Do you have spark at the plugs? Have you verified the fuel pump is working? Is the fuel making it to the combustion chamber?
Do you know how to check any of these things?
For more; http://www.ifitjams.com/starting.htm
Old 08-19-2013, 08:27 PM
  #25
Unregistered Member
Travis.'s Avatar
Travis. Travis. Travis. Travis. Travis. Travis. Travis. Travis. Travis. Travis. Travis.
take to junkyard have car crushed problems solved
Travis. is offline
Old 08-19-2013, 08:56 PM
  #26
neweather's Avatar
neweather has disabled reputation
its ur vtek fluids.
neweather is offline
Old 08-19-2013, 09:23 PM
  #27
shags420's Avatar
i figured it would moat likely be the starter but every one i have spoken to steered me away from that
shags420 is offline
Old 08-19-2013, 09:29 PM
  #28
shags420's Avatar
and Im pretty sure your car would run with out vtec
shags420 is offline
Old 08-19-2013, 11:47 PM
  #29
Digital Life
83Stang5.0's Avatar
If you can't tell if it's your starter or not, just give up now, walk away, don't turn back.
Old 08-20-2013, 04:25 AM
  #30
HAM
Heat's Avatar
Heat Heat Heat Heat Heat Heat Heat Heat Heat Heat Heat
I put a new dizzy
Yes I'm a Moron.
I dunno when fags starting calling shit a dizzy, but it's extremely gay and seems to be only honda idiots.
No one did this during the Fast and Furious glory days.
Heat is offline
Quick Reply: Car shut off going down the road, what's the problem?
