Car shut off going down the road, what's the problem?
Old 08-17-2013, 07:04 AM
shags420 has disabled reputation
Default Car shut off going down the road, what's the problem?
I put a new dizzy, new rotor button, new cap, new wires, and plugs, car cranks, but won't turn over. Its a ls vtec.. Please help
shags420 is offline
Old 08-17-2013, 07:40 AM
Fence Hopper
Alkaline8214's Avatar
Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214
Check your gas lol
Alkaline8214 is offline
Old 08-17-2013, 07:55 AM
TheMuhFuggin♂
burnoutboy's Avatar
burnoutboy burnoutboy burnoutboy burnoutboy burnoutboy burnoutboy burnoutboy burnoutboy burnoutboy burnoutboy burnoutboy
Default Re: Car shut off going down the road, what's the problem?
Is it cranking slow? What voltage is the alternator putting out?
burnoutboy is offline
Old 08-17-2013, 10:35 AM
Dough_Boy.'s Avatar
Did you check the timing belt to make sure it didnt break? Other than that actually check some shit, we can't fix it for you over the internet.
Dough_Boy. is offline
Old 08-17-2013, 10:58 PM
i pooped a squirrel
Gen_Crunchytoes's Avatar
Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes
timing could be off
plugs may not be gapped correctly
you might have gotten the firing order wrong
may have jumped a tooth or 2 on the timing belt
you need to post something other than the parts you threw at it.
Gen_Crunchytoes is offline
Old 08-18-2013, 08:59 AM
The firing order is right, i haven't check the alternator yet, I'm doing a compression test soon to see if my head has a bent valve, but also with the alternator all my lights are not dim...
shags420 is offline
Old 08-18-2013, 09:00 AM
and my timing belt is not broken.. and I can't even get the car started to time it right
shags420 is offline
Old 08-18-2013, 11:51 AM
yes and it is cranking real slow like it wants to go but it doesn't
shags420 is offline
Old 08-18-2013, 04:29 PM
Dillweed's Avatar
Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed
Doesn't make sense. Their talking about your mechanical timing.
Check fuel pump operation, check spark, check timing marks at cams,crank. Should line up at tdc.
Judging by your username stop smoking so much weed and read a book.
Dillweed is offline
Old 08-18-2013, 04:54 PM
VaDriven Mayhem
Lord Humongous's Avatar
Ok moron...was it running before you swapped the parts?
Lord Humongous is offline
Quick Reply: Car shut off going down the road, what's the problem?
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
