Car shakes when braking - What is it?
Old 10-28-2007, 10:49 AM
Full-time New Guy
Scottyk6's Avatar
Scottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud of
Default Re: Car shakes when braking - What is it?
Sounds good. I'll check them out, thanks for all the suggestions.
Scottyk6 is offline
Old 10-28-2007, 11:45 AM
Bearded.
DORKO's Avatar
bring me your rotors and ill cut them for you, for 40$
or you can get new rotors for like 100$
DORKO is offline
Old 10-28-2007, 03:37 PM
Originally Posted by naMfOrelliK
he'd get the shake at speed, not braking if it were alignment.
Your rotors are warped and you just need to get them cut. It'd be better to replace your pads too, but not necessary.
Not true, caster and toe can have different effects under braking. I would check the brakes first though.. I'm just throwing out other possibilities if it isn't the brakes.
Old 10-29-2007, 05:35 AM
Needs a fast car now
NX2KDET's Avatar
NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET
He has a point my old B13 would shake under braking conditions and it was really worn ball joints replaced the joints never did it again.
NX2KDET is offline
Old 10-29-2007, 05:47 AM
Slammedxpert
SortaFlush's Avatar
You can't always cut rotors if they are under discard thickness..
Don't be cheap, replace with new pads and rotors. Get Ceramic pads, semi matallic tend to put out alot of brake dust which can also induce a a lot of squeaking.
SortaFlush is offline
Old 10-29-2007, 07:41 PM
cleanEK's Avatar
could it also be a tire balancing issue?
cleanEK is offline
Old 10-30-2007, 04:55 AM
smuggling grapes
Speed-O's Avatar
Speed-O Speed-O Speed-O Speed-O Speed-O Speed-O Speed-O Speed-O Speed-O Speed-O Speed-O
not very likely. Another one of those things you'd mainly feel it at speed.
Speed-O is offline
Old 10-30-2007, 07:02 AM
Yes, that you'd feel. Alignment issues are largely geometry based, so you may only have problems when the suspension changes under weight transfer, etc. Tire balance would affect you at a given speed (or range of speeds) no matter what.
Old 10-30-2007, 01:52 PM
Slow as Shit
Woodrow's Avatar
I would look into the rotors first. 99.9% of the vibrating while braking issues we see are brake rotor related.
Woodrow is offline
Old 10-30-2007, 07:11 PM
RagPhoto.net
99CIVICFTW's Avatar
99CIVICFTW will become famous soon enough99CIVICFTW will become famous soon enough
got to the vb tech center. we'll resurface them mad cheap if not free. i go there and either i could do it or get a kid who is mad good at it to do it. i'm there 8-10 if you get there at like 8:30 you should be good. but i think you should go with new rotors. good luck
99CIVICFTW is offline
Quick Reply: Car shakes when braking - What is it?
