car alarm help
Old Apr 24, 2005 | 03:10 PM
Odysseus Prime's Avatar
Previously Odyssey
Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime
Default car alarm help
my friend has a 2001 lexus is300 and is going to install a car alarm. he needs a wiring diagram for his car..the dealership wants like 85 bucks for the maintinance book..any one know where he can find a wiring diagram for his car??
Old Apr 28, 2005 | 02:46 AM
demon2180's Avatar
RPR
demon2180 has disabled reputation
Default Re: car alarm help
go to a best buy and ask a tech to get one for you
Old Apr 28, 2005 | 04:14 PM
ForcedFedTeg's Avatar
loved by all
they wont give you one. i have a account with dirrectech.com ill pm you a link with the info you need.
Old Apr 28, 2005 | 04:24 PM
loved by all
12volts) white & white/red + ignition harness
Starter) black/white + ignition harness
Second Starter)
Ignition ) black/red + ignition harness
Second Ignition ) blue/red + ignition harness
Third Ignition)
Accessory) red + ignition harness
Second Accessory)
Keysense)
Power Lock) see direct fax
Power Unlock) document #1070
Lock Motor) green/yellow body ECU
Unlock Motor) blue/black body ECU
Parking Lights+) green driver kick, harness to rear
Parking Lights-) red headlight switch
Hazards)
Turn Signal(L)
Turn Signal(R)
Reverse Light)
Door Trigger) - body ECU
Dome Supervision) use door trigger
Trunk/Hatch Pin) red/yellow - driver kick, harness to rear)
Hood Pin) blue - alarm module
Trunk/Hatch Release) blue/white 5wi body ECU
Power Sliding Door)
Factory Alarm) Arm arms with lock
Factory Alarm Disarm) disarms with unlock
Disarm No Unlock) black/yellow - steering column
Tachometer) black igniter
Wait to start)
Brake Wire) green/white + brake pedal switch
Parking Brake)
Horn Trigger) green/white - steering column
Memory Seat 1)
Memory Seat 2)
Memory Seat 3)
Immobilizer Bypass Module
MAKE : LEXUS | MODEL : IS 300 | YEAR : 2001
hopefully that will help, if you know how to read it than that is all the info he will need.
Kris.Is.Foamin
Jul 13, 2008 07:42 AM
Iceman05
Aug 4, 2003 08:40 AM
