Bolt extraction from Aluminum LCA
Old 01-28-2015, 07:22 AM
BACK IN A G8
2ltrgsr's Avatar
Default Re: Bolt extraction from Aluminum LCA
Originally Posted by BAN HAMMER
is this the s4?
Yeah dude that installed the suspension broke them... He bought a new control arm with bolts... But you have to drop the rear subframe to have clearance to pull the bolt out on the forward bushing to be able to remove the lca
2ltrgsr is offline
Old 01-28-2015, 01:11 PM
Saabing Around
grkguy89's Avatar
grkguy89 grkguy89 grkguy89 grkguy89 grkguy89 grkguy89 grkguy89 grkguy89 grkguy89 grkguy89 grkguy89
tig weld on the bolt and build up enough material to grab with some vise grips.
the process of welding will heat it up to make it easy to break it loose....
takes far less effort then center punching and drilling for forever
grkguy89 is offline
Old 07-08-2015, 07:39 PM
west87's Avatar
west87 has disabled reputation
If all else fails helicoil. Could thread and tap a small bolt into the broken one and make a small bead on it.
west87 is offline
Old 07-09-2015, 06:26 PM
Standartenführer
euthorus's Avatar
euthorus euthorus euthorus euthorus euthorus euthorus euthorus euthorus euthorus euthorus euthorus
Advance sells a decent Lisle impact driver that can be socketed for a stripped nut extractor. You could gently apply that 200 ft. Lbs of torque to a right sized extractor over that bolt stub.
euthorus is offline
marlinspike
12-25-2012 02:17 PM
tdi520
05-07-2008 08:08 AM
BadBlackZ28
07-11-2007 11:16 AM
Quick Reply: Bolt extraction from Aluminum LCA
