bad gas mileage
Old Jul 18, 2008 | 04:44 PM
vxcoastie's Avatar
vxcoastie is a name known to allvxcoastie is a name known to allvxcoastie is a name known to allvxcoastie is a name known to allvxcoastie is a name known to allvxcoastie is a name known to allvxcoastie is a name known to all
Default Re: bad gas mileage
Originally Posted by ethan82000
will have to check that...is that the little black plastic plug in the airbox?? how would you go about cleaning that without damaging it?
That would likely be the IAT (Intake air temperature) sensor.
Old Jul 18, 2008 | 04:47 PM
ethan82000's Avatar
ethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond reputeethan82000 has a reputation beyond repute
ok that makes sense..then where is the map/maf sensor they're talkin about
Old Jul 18, 2008 | 04:50 PM
vxcoastie's Avatar
Small black electronic sensor right on top of throttlebody. MAP sensor go off pressures and MAF sensors go by airflow. Let me see if I can get a pic of it...
Old Jul 18, 2008 | 04:57 PM
vxcoastie's Avatar
http://www.ridejudge.com/rides2/14011.jpg
Right in the center of the pic, below the strut bar.... Small black sensor.
http://www.d-a-p.com/shop/ProdImages/DSC00820%20S.JPG
Old Jul 18, 2008 | 05:06 PM
ethan82000's Avatar
that helps a lot...how would i clean that without harming it
Old Jul 18, 2008 | 05:21 PM
vxcoastie's Avatar
you don't. If it doesn't work, it'll throw a "CEL".
Old Jul 18, 2008 | 05:22 PM
ethan82000's Avatar
o ok well no cel
vxcoastie's Avatar
It's a sealed unit
Old Jul 18, 2008 | 05:25 PM
vxcoastie's Avatar
Did she try fuel additives/cleaners??
Old Jul 18, 2008 | 05:28 PM
Vampyrate's Avatar
Vampyrate is an unknown quantity at this point
x2 on the injector cleaner. most of the ones that ive seen are snake oil, so i really dont know of any company other than amsoil or BG to look into for that. other than that, i would have the fuel pump/filter checked as well
