b18c1 making odd noise..Help
So lately my b18c1 starting makeing an odd noise. I was running 5psi on stock internals for months with no problems. Then I ran 7psi on stock internals for less then 10 minutes and when i parked it , the next morning it started sounding like a lifter was bad. I checked the lifters and they seem to be fine. Anyone know what else could be wrong?
Re: b18c1 making odd noise..Help
Originally Posted by GSRswapEk
(Post 6832153)
well rocker arms or wt ever,.. Any suggestions of wts making the noise?.. Like could a valve be messed up or something?
a noise with a motor is hard to determine over the internet, it could be a rod knock, valve tick or both.
where are you located? |
eastern WV, im hopeing its something like a valve adjustment or something
take it some place.. like nasthatch said it super hard to pin point via internet
is it a loud fast ticking noise, or does it sound like metal on metal death?
or does it sound a subie with an exhaust? could be a stuck or bent valve, snapped connecting rod...or your valves might just need adjusting |
Originally Posted by NasTHatch
(Post 6833462)
or does it sound a subie with an exhaust? could be a stuck or bent valve, snapped connecting rod...or your valves might just need adjusting And is there a way you could get a video up of the car running? That would make it a little bit more easier of identifying the problem. |
This is something to ask about. What fuel management are you using?
heck even an FMU is "safe" at these levels but . . .
(Post 6832153)
Originally Posted by Laserjock
(Post 6833935)
heck even an FMU is "safe" at these levels but . . . |
