b18c1 making odd noise..Help
Old 01-14-2011, 03:05 PM
GSRswapEk's Avatar
GSRswapEk has disabled reputation
Default b18c1 making odd noise..Help
So lately my b18c1 starting makeing an odd noise. I was running 5psi on stock internals for months with no problems. Then I ran 7psi on stock internals for less then 10 minutes and when i parked it , the next morning it started sounding like a lifter was bad. I checked the lifters and they seem to be fine. Anyone know what else could be wrong?
GSRswapEk is offline
Old 01-14-2011, 03:17 PM
breath
tucker5129's Avatar
tucker5129 tucker5129 tucker5129 tucker5129
Default Re: b18c1 making odd noise..Help
since when do GSR's have lifters??
tucker5129 is offline
Old 01-14-2011, 08:24 PM
GSRswapEk's Avatar
well rocker arms or wt ever,.. Any suggestions of wts making the noise?.. Like could a valve be messed up or something?
Old 01-14-2011, 08:29 PM
RIP DRAGVA-2016
NasTHatch's Avatar
a noise with a motor is hard to determine over the internet, it could be a rod knock, valve tick or both.
where are you located?
NasTHatch is offline
Old 01-15-2011, 08:33 AM
GSRswapEk's Avatar
eastern WV, im hopeing its something like a valve adjustment or something
Old 01-15-2011, 08:41 AM
breath
tucker5129's Avatar
take it some place.. like nasthatch said it super hard to pin point via internet
Old 01-15-2011, 10:04 AM
RIP DRAGVA-2016
NasTHatch's Avatar
is it a loud fast ticking noise, or does it sound like metal on metal death?
or does it sound a subie with an exhaust?
could be a stuck or bent valve, snapped connecting rod...or your valves might just need adjusting
Old 01-15-2011, 11:06 AM
BROSCIENCE
DwiZZy's Avatar
DwiZZy DwiZZy DwiZZy DwiZZy DwiZZy DwiZZy DwiZZy DwiZZy DwiZZy DwiZZy DwiZZy
^this
And is there a way you could get a video up of the car running? That would make it a little bit more easier of identifying the problem.
DwiZZy is offline
Old 01-15-2011, 03:42 PM
Stiff Member
Laserjock's Avatar
Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock
This is something to ask about. What fuel management are you using?
heck even an FMU is "safe" at these levels but . . .
Laserjock is offline
Old 01-15-2011, 06:31 PM
RIP DRAGVA-2016
NasTHatch's Avatar
my friend ran 12 pounds daily on a stock ls for 5 years.....
Quick Reply: b18c1 making odd noise..Help
