B18 CLUTCH HELP ASAP!!!
Old Feb 16, 2007 | 06:22 PM
sick89six's Avatar
sick89six is a jewel in the roughsick89six is a jewel in the roughsick89six is a jewel in the rough
Default B18 CLUTCH HELP ASAP!!!
I bought a b series cm fx300 clutch for my car. (current one is slipping) It is a 1995 Integra GSR turbo. I am going to put the clutch in tommorow and the guy i bought it from just told me that it was out of his b16 crx with cable tranny. WILL THIS CLUTCH WORK???????
THANK YOU VERY MUCH!
-Andrew
Old Feb 16, 2007 | 06:51 PM
MORE IMPATIENT's Avatar
DESTROYS DONUTS !!
Default Re: B18 CLUTCH HELP ASAP!!!
nope. i think the pressure plate is different, the clutch plate may work.
Old Feb 16, 2007 | 07:17 PM
kyle h.'s Avatar
fraggle rock
kyle h. will become famous soon enough
cable clutch != hydro clutch
Old Feb 17, 2007 | 05:09 AM
integrarj's Avatar
no
Old Feb 17, 2007 | 05:27 AM
sick89six's Avatar
well its the disc that im having a problem with. the pressure plate fits the flywheel perfect.! Im in Virginia Beach. Does anyone know where I can get a clutch today or tommorow!
thanks
Old Feb 17, 2007 | 02:46 PM
hondub's Avatar
I fix cars
hondub is an unknown quantity at this point
Bap Geon or even Advance Auto. I know Advance carries stage 1 and 2 clutches made by Luk.
Old Feb 17, 2007 | 06:43 PM
RPRacing's Avatar
Huntin Dropa ForLife
RPRacing has disabled reputation
nope backwards. and maybe
here is the rundown
90-91 B series use a small spline input shaft/clutch
92-93 B series are still cable clutch, but use a bigger Hydro size input shaft/clutch.
If the clutch disc isnt sliding on easy, is not going to work. dont force it.
Old Feb 19, 2007 | 07:40 PM
Boi Boi's Avatar
Boi Boi is an unknown quantity at this point
here is the rundown
well how will u know if the clutch from b16 came from 90-91 or 92-93?
Old Feb 19, 2007 | 08:00 PM
will_rex's Avatar
will_rex has a reputation beyond reputewill_rex has a reputation beyond reputewill_rex has a reputation beyond reputewill_rex has a reputation beyond reputewill_rex has a reputation beyond reputewill_rex has a reputation beyond reputewill_rex has a reputation beyond reputewill_rex has a reputation beyond reputewill_rex has a reputation beyond reputewill_rex has a reputation beyond repute
here is the rundown
As stated before, the earlier years use a smaller input shaft spline therefore the clutch disc will have a smaller hole. The 92-93 models are larger, the same size as late model B-series hydro's. I don't know the exact demensions, but if it doesn't slide on with relative ease, it's obviously not the correct one.
My .02, buy a new one for your car so you'll know if it's going to fit or not. If you don't know much about parts and such, why waste money on something you're not sure is going to fit?
sick89six
Aug 12, 2008 07:33 AM
