b16a oil pressure sender
Old 08-13-2013, 01:10 PM
treybr13's Avatar
treybr13 has disabled reputation
Default b16a oil pressure sender
If I use an aftermarket oil pressure sender will it throw a code?
treybr13 is offline
Old 08-14-2013, 09:43 AM
Default Re: b16a oil pressure sender
Possibly. That's a pretty open-ended question. There are a lot of aftermarket sensors out there.
Old 08-14-2013, 11:06 AM
Dillweed's Avatar
Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed
Perhaps the code is coming on for a reason and the sensor is functioning as it should. Hooking up an oil pressure gauge to spot where the sensor goes will tell you if your pressure is good and there is an electrical fault. If that is the case then get the wiring diagram and grab a DMM and figure that shit out instead of throwing parts at it.
Dillweed is offline
TRAVIS058
05-24-2011 07:24 AM
mnchvgs79
12-27-2004 09:04 PM
†Specter†
10-01-2003 12:48 PM
Quick Reply: b16a oil pressure sender
