B16a hits hood
Old Sep 17, 2003 | 01:18 PM
MA-HALF-E's Avatar
Awesome.
Originally posted by 93LudeSi
He used hasport mounts, but the driver side mount wouldn't fit so he's only got 2 hasports and one stock mount lol...everything john does is ghetto
I'm a little pissed off about the mounts not fitting. It doesn't seem to be hitting the hood now that it's on the ground and not 5 feet off it at a 60 degree angle.
Old Sep 17, 2003 | 08:23 PM
Grease Monkey's Avatar
Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey
I thought that when you did that swap you needed to use the SIR hood.. I thought there was a difference in the shape of the hood
edit: Sorry, maybe that is on the earlier cars
Old Sep 18, 2003 | 05:23 AM
B16ASilverHonda's Avatar
FredVegas
B16ASilverHonda has a spectacular aura aboutB16ASilverHonda has a spectacular aura about
I had the same problem, it was bad motor mounts. Make sure all your mounts are good and your motor isnt coming up to hit your hood...
Old Sep 18, 2003 | 05:33 AM
MA-HALF-E's Avatar
Awesome.
Definitely bad motor mounts.
Old Sep 18, 2003 | 06:25 AM
MegaH_MaN's Avatar
WRX 0-60: NOW!!
MegaH_MaN has a little shameless behaviour in the past
how much space do you need? I had a friend with a b16CRX with the same problem. So he went dremmel happy on the underside of the hood. He just cut the thick parts of the hood so you couldnt tell unless you loked underneath.
Old Sep 18, 2003 | 10:22 AM
EEK's Avatar
EEK
卐 Walnuts
mine use to hit the hood but it was because i need motor mount inserts
Phade
Feb 3, 2004 08:15 PM
