b16a crx hf shaking problem.
Old Nov 21, 2008 | 08:14 AM
border919's Avatar
border919 has disabled reputation
Default b16a crx hf shaking problem.
i havea a jdm b16a with crx sir axles and half shaft in my car.the car just shakes during acceeleration only.do you think this could be my alingment.the swap came from another car.i checked to make sure everything is tight.it is a lowered car.the parts car that the motor and axls were in didnt have a shaking problem.any suggestions
Old Nov 21, 2008 | 08:19 AM
santanard's Avatar
santanard has disabled reputation
Default Re: b16a crx hf shaking problem.
how bad does it shake? probly gona say its ur axles cause thats what it was on my bros integra.
Old Nov 21, 2008 | 11:12 AM
border919's Avatar
its just a little.the first drive 25miles it didnt shake.now it shakes.i made sure everythings tight.so
Old Nov 21, 2008 | 03:01 PM
wright's Avatar
What gear does it shake? Is it all gears? I am having the same issue and I think that it is my Diff. If you jack up the front of the car so the wheels are not on the ground of course, you can put the car in gear while it is running to see if the trans or axles are making a noise. Also you should be able to stop one wheel at a time to rule out the axles or axle.
Good luck
Old Nov 23, 2008 | 07:20 PM
D-Rizzle's Avatar
D-Rizzle has disabled reputation
A friend of mine's hatch was doin that and it turned out to be the halfshaft was bad. The car shook so bad that the lugnuts came loose...try that or axles.
Old Nov 24, 2008 | 08:49 AM
border919's Avatar
i put in a brand new axle,still shakes but only sometimes.the old axle was clicking anyways.im not sure what i should try next.it is weird that it didnt shake when i first took it to school.but then on the way home it started to shake.i did find out that the steering arm bolt had come loose.could this have affected it?i could mess around with different positions.
Old Nov 24, 2008 | 03:29 PM
border919's Avatar
Old Nov 24, 2008 | 03:41 PM
DORKO's Avatar
Bearded.
unbalanced wheels?
lug nuts loose?
Old Nov 24, 2008 | 06:17 PM
border919's Avatar
the wheels are balanced and lugnuts are tight.the car didnt shake on the way to school but then it started when i was coming back home.i did hit a big pothole
Old Nov 26, 2008 | 04:59 AM
sleekef's Avatar
sleekef is infamous around these partssleekef is infamous around these partssleekef is infamous around these partssleekef is infamous around these partssleekef is infamous around these partssleekef is infamous around these partssleekef is infamous around these partssleekef is infamous around these partssleekef is infamous around these partssleekef is infamous around these partssleekef is infamous around these parts
When swapping my B-series into my crx i had to double check the axles. Make sure its ALL the way in to the hub.. It might look like its in there but check again. Also, how are your wheel bearings?
Tiny Tim
Mar 24, 2005 03:51 AM
CReX
Apr 20, 2004 07:11 AM
CRXtacy
May 12, 2003 04:45 PM
