>----B16 repair...HELP!----<
Old May 21, 2005 | 12:32 PM
WOODman's Avatar
WOODman is an unknown quantity at this point
Default >----B16 repair...HELP!----<
Does anyone have info on how I can fix a stripped main pulley shaft on the crank shaft of a B16? Im just looking for some way(s) to fix this problem…
1) the shaft coming out of the crankshaft that goes into to the belt pulley is stripped and F***ed up, and so is the pulley itself (someone left the key out and it spun inside the pulley till it destroyed itself)
2) can I repair the shaft?
3) can I find a whole B16 crankshaft somewhere, if so the where? About how much?
Old May 21, 2005 | 12:57 PM
MORE IMPATIENT's Avatar
DESTROYS DONUTS !!
Default Re: >----B16 repair...HELP!----<
i may be mistaken but ive never heard of a driveshaft connecting into a pulley on a b16, if someone left the KEY out(crank KEY WAY), i would assume you are referring to the crank pulley and that the crank side that slides into the crank pulley is fucked up. please explain further, from what i am taking your crank pulley and crank are fucked.....
Old May 21, 2005 | 01:18 PM
WOODman's Avatar
thats exactly it... the key for the crank pulley was left out so it destroyed the shaft and the pulley...does that help
Old May 21, 2005 | 06:33 PM
DESTROYS DONUTS !!
well if it destroyed the shaft on the crank w/ the insert slot for the key way, then your fucked, if you cant get that key way in there correctly you wont be able to keep keep the pulley from destroying itself again and or be able to get the car at TDC reffering to the marks, that key way lines up with the crank pulley which in turns lines up with timing marks. if you cant get that to line up properly and the crank pulley to seat correctly then your kinda screwed but if you can get it to seat you can always fucke with it until timing gets correct.....if the insert for the key way is still there and useable, you might be able to put a key way in there and be ok, but the pulley might not seat correctly because of the lack of circumfrence on the crankshaft. if it hasnt ate through the crankshaft seal on the oil pump then i would try it and see how it works out.
Old May 22, 2005 | 06:22 AM
If it's that bad, start looking for another crank, or just grab an entire shortblock from somewhere.
Old May 22, 2005 | 06:42 AM
CHAHONDA's Avatar
corona connessuer
where is the car located?? i may be able to help but i have to see what exactly you are talking about
Old May 22, 2005 | 08:56 AM
WOODman's Avatar
its in durham by northern high school...im going out today(sunday) too assess it...919-697-5570 if you are in the area
professorman
May 19, 2008 02:03 PM
Broke Neck
Dec 20, 2007 07:59 PM
volklover
Feb 10, 2007 06:53 PM
jay357
Jun 18, 2006 08:20 PM
