b-series turbo problem
Old Jun 1, 2006 | 10:34 AM
2ltrgsr's Avatar
BACK IN A G8
Default b-series turbo problem
my car is misfiring and the plugs are black also smells like gas i replaced the plugs last night and its still doing this does anyone have any suggestions on what it could be also checked timing and its fine, it has a cel 72 or misfire code.
Old Jun 1, 2006 | 10:43 AM
92EH3's Avatar
92EH3 has disabled reputation
Default Re: b-series turbo problem
check your wires and distrubitor
Old Jun 1, 2006 | 04:04 PM
88CRXHFBSTNG's Avatar
88CRXHFBSTNG has disabled reputation
NEED MORE INFO. what is your set up? what engine management you running? what size injectors? etc. etc.
Old Jun 1, 2006 | 04:25 PM
2ltrgsr's Avatar
BACK IN A G8
fmu and i got 310cc injectors.
Old Jun 1, 2006 | 04:29 PM
sohc_mshue's Avatar
have you tried running 240cc injectors? Those injectors are gonna run a little rich at part throttle with that setup.
Old Jun 4, 2006 | 06:00 AM
2ltrgsr's Avatar
BACK IN A G8
the car starts and runs now i replaced the distrubutor but it still is running rich and misfires at vtec
Old Jun 4, 2006 | 06:14 AM
Brnguy's Avatar
Brraaap!
Brnguy Brnguy Brnguy Brnguy Brnguy Brnguy Brnguy Brnguy Brnguy Brnguy Brnguy
How much boost you runnin?? what plugs do you have in your car.. Fuel pump?? is timing on.. not retarded or advanced?? grade fuel runnin?? fpr?? what kinda air/fuel gauge you got??? I got a stock y8 runnin 9 psi stock injectors, fmu, and 255 fuel pump.. no piggy back or any kind of fuel control.. Let me know what ya got on your car. maybe i can help ya out!
Old Jun 4, 2006 | 06:16 AM
spooledex's Avatar
spooledex spooledex spooledex spooledex spooledex spooledex spooledex spooledex spooledex spooledex spooledex
What did you gap them at? Take them down to like .028
Old Jun 4, 2006 | 06:19 AM
Brnguy's Avatar
Brraaap!
Gap them to stock gap!!! that only works for dsm's. not good for honda. need to know what plugs he's runnin first!???
Old Jun 4, 2006 | 06:20 AM
2ltrgsr's Avatar
BACK IN A G8
k i will look at the gap
