Anybody know how much power this would be?
Hey, i am going to be putting in a b16a2 engine in a 1995 civic lx. I have also a magnaflow exhaust (cat-back), a short ram intake, and going to add a lightweight flywheel, and a performance clutch kit. Anybody know how much power this would be pushing? I was thinking around 200 for sure. Cuz the engine itself is 170, but let me know guys.
I think it would be more than that. The engine itself is 170 so how can a cat-back exhaust, a short ram intake, and a lightweight flywheel only add 5 hp?
180 crank if you're lucky. it'll still be a quick little monkey
170 + short ram = 171 or 172
172 + exhaust = 177ish
flywheel = nothing at the crank.
the lightweight flywheel will free up a lot of horsepower being used to spin the heavy stock flywheel. So how could this add nothing?
You can't believe HP claims first off. 170 at the crank is good for about 140. Plus your simple bolt-ons are usually only good for +/- 5 hp at the most. Yes you can actually lose hp from your bolt-ons, but pick up some torque. and you lightweight flywheel will help out mostly with your throttle response. That is where you will feel the most gain from that.
