All Honda tech gurus, please check out this problem.
Old Nov 11, 2003 | 07:06 AM
TempestRex's Avatar
The Wizard
TempestRex is a name known to allTempestRex is a name known to allTempestRex is a name known to allTempestRex is a name known to allTempestRex is a name known to allTempestRex is a name known to all
Default All Honda tech gurus, please check out this problem.
Alright i just did a mini me conversion. I used an A6 block and a Y8 head. Im using an 88 integra ecu for this swap. The big problem is that cylinder 2 wont fire or it seems to be not firing corectly. Im kind of stuck on it, i have some ideas but i need more input. Feel free to ask questions i will answer them. Thanks for your time
Old Nov 11, 2003 | 07:10 AM
CHAHONDA's Avatar
corona connessuer
why are you using a teg ecu???
did you check the firing order????? seems like you may have 2 wires crossed!
Old Nov 11, 2003 | 07:11 AM
MORE IMPATIENT's Avatar
DESTROYS DONUTS !!
could the ecu be the problem since the integra was a zc non vtec and you have a vtec head on the car now? what about your wiring harness, did you have to add anything to that at all to wire up vtec like on a b series.......i have no idea about mini me conversions so im just tossing ideas out........
Old Nov 11, 2003 | 07:12 AM
DESTROYS DONUTS !!
Old Nov 11, 2003 | 07:20 AM
CHAHONDA's Avatar
corona connessuer
yeah thats what i said!!
its very easy to have 2 wires crossed and it seem to idle ok but run like ass when you rev it up!
Old Nov 11, 2003 | 07:27 AM
TempestRex's Avatar
The Wizard
its the other way around on the car, it revs fine but idles like shit. firing order is ok, 1-3-4-2, wires are straight.
Old Nov 11, 2003 | 07:30 AM
kawgomoo's Avatar
fabricated reality
kawgomoo can only hope to improve
ill take a look at it for you. if youd like.... not sure what model your car was to begin with but there are some wiring changes that have to be made... probalby tps, or injector wiring is kinda dicked up. then again it could be anything.....
Old Nov 15, 2003 | 10:40 AM
And before you run around in circles too much, make sure the ECU is working properly too, you may have a bad injector output. It's rare, but it happens.. Try a known-good ECU and see if the problem is still there.
Old Nov 16, 2003 | 09:00 PM
Dr. On Point's Avatar
NOVAS FINEST
Dr. On Point Dr. On Point Dr. On Point Dr. On Point Dr. On Point Dr. On Point
u need to be more specific.....
do u have spark?
do u have fuel?
did you try different injectors?
did you try a different ecu?
ur question is vague... u mine as well say my car doesnt start, whats up with that?
Old Nov 19, 2003 | 11:18 AM
cbucgo's Avatar
cbucgo is an unknown quantity at this point
do a power balance test to see if your injector is working properly. if your idle drops, everything is fine. if not, you have a bad injector.
