accord blower motor
accord blower motor
my girlfriend has a 93 accord se. When you cut the A/C or the heater on, you can hear the valves in the heater ducts changing but just no air moving.
I have checked the fuses and all So I assume its the blower motor. any diagrams or pictures to help me remove it?? Thanks
Re: accord blower motor
The same thing happened to my accord and I ended up getting a used blower motor from the junkyard and putting it in. It really isn't that difficult. The Haynes Repair manual shows you how to remove it. You have to remove the glove box to give yourself more room and then after that it is basically just unbolting the blower and unhooking a couple of wires.
does the motor work on the two highest speeds?if so its a bad blower resistor if not it is a bad blower and its not hard ive done atleast 2 of them!the resistor sit's right in front of the blower under the pass. side of dash!Might take an hour or so if never done before!
ok guys I guess Ill buy a used one . its not the resistor, thats the first thing I checked since my last accord did that. thanks guys
