ABS Trouble Codes Help
98 Integra 4dr GSR
Just recently put in a test pipe and now getting ABS Trouble codes.
81=CPU,
16=Wheel Sensor (electrical noise/intermittent interruption),
61=Ignition Voltage.
Can someone help me fix this problem? ABS light doesn't show when running only when diagnosting.
I'm at 757 and would give cash to fix....
I also got a couple of things need to be put in but i have no time.
Spark Plugs
Spark Plug wires
Fuel Filter
Pretty much trying to tune since its on high mileage.
81=CPU,
Spark Plugs
Spark Plug wires
Fuel Filter
Re: ABS Trouble Codes Help
For he ABS problem did you cheack the air gap(copper feeler gauge)? Or look for metal shavings on the sensor? If the the ABS light is not on all the time you should be fine cause hitting a pothole can change wheel speed on that one wheel for a second and trip a ABS code even though nothing is wrong.
yea i had the car jacked and ran the engine, one wheel was on ground and other was spinning on idle. Maybe reset ECU can fix?
how about the ignition voltage?
Ignition voltage can be a number of things from high resistance in you spark plugs wires to your coil being bad. If you have the dealership manual it will show you trouble trees on how to go about finding the problem before you start spending money on parts.
I just got done finding an open on ground side of map sensor puting my car in limp mode. Map sensor was fine but the wireing from the ECU made it look like a bad map sensor. Think smart not hard
