97 Civic GSR Swap Help!
Old 06-17-2010, 04:26 PM
シビックタイプR
boostorbust's Avatar
boostorbust has disabled reputation
Default 97 Civic GSR Swap Help!
ok just got the motor in, used my civic harness on the motor. Unpluged the single cam ecu inside and it has four connectors going into it, but my gsr ecu only has space for three conectors?! I know about the whole obd2a and obd2b stuff so i am using a 97 p72! HELP PLEASE!!!
boostorbust is offline
Old 06-17-2010, 06:37 PM
brandon.beene's Avatar
brandon.beene can only hope to improve
Default Re: 97 Civic GSR Swap Help!
what are you needing help with? get you a jumper harness, and wire in vtec.
www.hondoogle.com
brandon.beene is offline
Old 06-17-2010, 09:30 PM
If your GSR ECU only has 3 connector positions, it's not a 97 ECU. All 96 and up Honda ECUs have 4 connector positions, but only 3 positions are used. OBD2a and OBD2b don't use the same 3 positions out of the 4 available positions.
Is your Civic an automatic? I can't remember if the 4th connector position on OBD2 Honda stuff is for auto trans functions or something like that..
I'm not sure if we completely understand what you're saying...
Old 06-18-2010, 02:29 AM
シビックタイプR
My civic was auto before
Old 06-18-2010, 06:57 AM
That's why you have 4 connectors on the harness. I don't ever do anything with auto trans cars, but I would assume that the fourth plug is auto trans functions only so you can probably just not use that plug. Honda generally uses a very standard pinout, so the main 3 connector positions should be identical pinout for the manual and auto trans ECUs I would imagine.
Old 06-18-2010, 09:20 AM
シビックタイプR
thanks for the help! this is the fist auto shell that i am doing a swap into
sailainn
02-16-2010 09:32 AM
95vadsm
12-10-2007 07:15 PM
EGon10psi
05-26-2007 02:06 PM
Quick Reply: 97 Civic GSR Swap Help!
