'97 Civic 5 speed shudder from a stop (clutch)
What would cause my Civic to shudder when leaving from a stop? It's similar to a shudder I've felt in a car with a really strong twin disk clutch. When taking off from a stop, it shudders pretty bad when slipping the clutch out. It's worse when it's cold and all but goes away when it's warm.
Disclaimer, it's an old piece of shit but I bought it real cheap. It hasn't lived a pampered life.
VaDriven Mayhem
Re: '97 Civic 5 speed shudder from a stop (clutch)
I guess all 115hp are needed elsewhere
TAINT PUNCHER!
Bad clutch fade I would assume. It's like a car with badly faded brakes or warped rotors. Could be the flywheel needing to be turned causing irregular clutch disk mating.
TAINT PUNCHER!
The clutch could also be glazed over due to asshat driving, or someone not knowing what they were doing, I'm only assuming this because of statement about recently acquired.
TAINT PUNCHER!
Unless you just want to because the motor is bad.
Usually a glazed disc or a heat checked friction surface. It can also be from a bearing problem or lack or proper lubrication during clutch engagement. I'm going to put my money on a cold clutch with a little glazing.
