97 Accord - Replacing Oil Pressure Switch
Is it possible to replace the oil pressure switch without jacking the car up and going underneath?
The car is a 97 Honda Accord 2.2 non-vtec.
Thanks.
Thanks.
Re: 97 Accord - Replacing Oil Pressure Switch
OP, do you have the new switch? Do you have a deep socket of the correct size, extension, ratchet? Do you know where it is located? Can you get your hand on it and a flat screwdriver to pry the boot off? Do you have some sort of thread sealant to install the new one. Did you know that the boot will be hard as a brick in these temps and will most likely rip (assuming since you have no jack or stands that it will not be in a heated garage). If you can answer NO to any of these, pay someone else to do it.
Is this boot not replaceable? I'm assuming its going to be brittle as its been on there for 16 years.
Why would I pay someone to do this? It seems simple enough.
Also google is your friend, http://www.ehow.com/how_5882215_repl...re-switch.html. <-----this will be the same procedure.
