94 Civic HG problem, radiator issue???
Old 03-19-2013, 12:47 PM
grant90's Avatar
grant90 has disabled reputation
Default 94 Civic HG problem, radiator issue???
I'm having an issue with my civic.
I had a radiator flush a few months ago, the put a 16lb cap back on it once they were done. 2 weeks ago, it busted the heater hose (I fixed it). Then over the weekend I drove it to hampton turned it off and let it sit about 20min. After starting it again and almost making it to the light it started sputtering, exhaust note kinda sounded like an STi and then it started bellowing smoke when and only when I tap on the gas. Today, I drove it for about 10 minutes and it was fine until it warmed up. Once it was warm the sputtering came back and it started smoking once I pushed on the gas pedal.
I checked for the usual sign of HG failure, I looked at the oil cap and there were no signs of coolant leaking. The I pulled the dipstick, no signs there either. The oil still looks brand new, I can't for the life of me figure out what the problem is.
grant90 is offline
Old 03-19-2013, 06:25 PM
Default Re: 94 Civic HG problem, radiator issue???
Test the coolant temp sensor that goes to the ECU. Is it a new radiator cap?
Old 03-20-2013, 04:30 AM
grant90's Avatar
I was hoping you were still on here.
The cap was put on back in November, so it's fairly new.
grant90 is offline
Old 03-20-2013, 04:43 AM
Digital Life
83Stang5.0's Avatar
Are you throwing any codes?
The symptoms you already described fit fine for a headgasket failure. Depending on where the gasket gives, you may not always be able to see certain tell-tale signs of failure. I had a bad headgasket going over a few months, caused alot of pressure build up in the cooling system, but never gave any easily ID'able signs until it finally went on the interstate one day.
83Stang5.0 is offline
Old 03-20-2013, 05:44 AM
sleeperteg's Avatar
sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg
The headgasket might have failed in a spot where it is not leaking coolant into the oil, however it could be leaking combustion into the cooling system and coolant into your combustion chamber. That would explain why you blew a hose and the sputtering/smoking.
sleeperteg is offline
Old 03-20-2013, 05:52 AM
Flatulence
PicovAndropov's Avatar
PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov
Pull out the spark plugs and pressure test the cooling system. Let it sit for about 20 mins with pressure. After that, look inside the spark plug hole and see if you have any moisture in the cylinders.
PicovAndropov is offline
Old 03-20-2013, 06:37 AM
grant90's Avatar
No, the check engine light hasn't been on ever.
I'm gonna have it picked up today or tomorrow, it's a jasper engine so hopefully they'll cover a new one.
grant90 is offline
Old 03-20-2013, 07:16 AM
walmar1950's Avatar
walmar1950 has disabled reputation
Check to make sure da gas line dat suppose to goin to da charcoal canister not goin to the intake i had da same problem my lines got crossed sumwhea once i changes it it ran fine had my coolant and a gas line crossed
walmar1950 is offline
Old 03-20-2013, 07:33 AM
I can't read this without mentally adding a funny accent. Well, I can't read it at all actually. Delete?
Old 03-20-2013, 07:35 AM
Digital Life
83Stang5.0's Avatar
bahaha I just read this aloud on the train, everyone around me started laughing
Quick Reply: 94 Civic HG problem, radiator issue???
