94 Civic HG problem, radiator issue???
I'm having an issue with my civic.
I had a radiator flush a few months ago, the put a 16lb cap back on it once they were done. 2 weeks ago, it busted the heater hose (I fixed it). Then over the weekend I drove it to hampton turned it off and let it sit about 20min. After starting it again and almost making it to the light it started sputtering, exhaust note kinda sounded like an STi and then it started bellowing smoke when and only when I tap on the gas. Today, I drove it for about 10 minutes and it was fine until it warmed up. Once it was warm the sputtering came back and it started smoking once I pushed on the gas pedal. I checked for the usual sign of HG failure, I looked at the oil cap and there were no signs of coolant leaking. The I pulled the dipstick, no signs there either. The oil still looks brand new, I can't for the life of me figure out what the problem is. |
Re: 94 Civic HG problem, radiator issue???
Test the coolant temp sensor that goes to the ECU. Is it a new radiator cap?
Originally Posted by Fabrik8
(Post 8102742)
The cap was put on back in November, so it's fairly new. |
Are you throwing any codes?
The symptoms you already described fit fine for a headgasket failure. Depending on where the gasket gives, you may not always be able to see certain tell-tale signs of failure. I had a bad headgasket going over a few months, caused alot of pressure build up in the cooling system, but never gave any easily ID'able signs until it finally went on the interstate one day. |
Originally Posted by grant90
(Post 8102436)
Pull out the spark plugs and pressure test the cooling system. Let it sit for about 20 mins with pressure. After that, look inside the spark plug hole and see if you have any moisture in the cylinders.
Originally Posted by 83Stang5.0
(Post 8102965)
The symptoms you already described fit fine for a headgasket failure. Depending on where the gasket gives, you may not always be able to see certain tell-tale signs of failure. I had a bad headgasket going over a few months, caused alot of pressure build up in the cooling system, but never gave any easily ID'able signs until it finally went on the interstate one day. I'm gonna have it picked up today or tomorrow, it's a jasper engine so hopefully they'll cover a new one. |
Check to make sure da gas line dat suppose to goin to da charcoal canister not goin to the intake i had da same problem my lines got crossed sumwhea once i changes it it ran fine had my coolant and a gas line crossed
Originally Posted by hotsauce278555
(Post 8103141)
(Post 8103174)
I can't read this without mentally adding a funny accent. Well, I can't read it at all actually. Delete?
