92 civic 4 door code 43???
Old 07-05-2010, 01:10 PM
WannaBboosted's Avatar
WannaBboosted has disabled reputation
Exclamation 92 civic 4 door code 43???
ok so i threw a check engine light and i found out that its a code 43 fuel supply sytem supposedly. Now what should i be checking out fuel injectors ? or is it common for supthing else to happen? thanks for any help with this.
WannaBboosted is offline
Old 07-07-2010, 10:40 AM
Default Re: 92 civic 4 door code 43???
Old 07-07-2010, 06:57 PM
Stiff Member
Laserjock's Avatar
Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock
See if the connectors to the injectors came loose - very unlikely.
Measure the resisitance across the 2 pins of each injector and compare with the others
Saturated injectors 12-16 Ohms. If measured below 10 Ohms, replace.
Laserjock is offline
spider71
07-27-2004 12:58 PM
Quick Reply: 92 civic 4 door code 43???
