90 integra ls needs to just adjust cam gears for racing.
Re: 90 integra ls needs to just adjust cam gears for racing.
1990-91 RS,LS,GS COUPE
ENGINE
Engine code: B18A
valvetrain: 4 valves per cylinder, belt-driven, dual overhead camshafts
Horsepower (hp), SAE net: 130@ 6000RPM
Torque (lbs-ft), SAE net: 121 @ 5000RPM
Redline: 6500 RPM
Bore X Stroke: 81mm x 89mm (3.19 in x 3.50 in)
Displacement: 1834cc (112 cu in)
Compression Ratio: 9.2:1
ENGINE
Engine code: B18A
Redline: 6500 RPM
Originally Posted by MORE IMPATIENT
b18b- 142 hp to the flywheel.........calculate your 15 % drivetrain loss, less than 120 to the wheels.....LEARN SOMETHING FIRST BEFORE YOU POST THAT YOU KNOW YOUR CAR HAS 180 HP TO THE WHEELS WITH ONLY A BUILT HEAD BECAUSE IT WILL NOT MAKE THAT MUCH POWER.......ive seen fully built gsr motors running 12:1 compression with 5k dollars in head work done, standalone engine management and everything aftermarket for lightweight and a balanced rotating assembly and there only making 187 to the wheels, i am running 11:6:1
compression, with a stock ls head and i made 132hp to the wheels and thats with an hour of dyno tuning and the motor only had 1k miles on it when i dynoed it, i rebuilt it and swapped it in and then dynoed it(i know the head makes alot of difference, but an ls head, no matter how built it is will never be worth 50 hp).......with your low compression and depending on what type of cams you are running(crower i would assume for a good ls n/a setup), i say you will make a MAXIMUM of 150HP if it is tuned by an extremely talented tuner , and thats pushing it, and that short ram intake isnt doing shit for you except making a sound, your clutch isnt gonna create power, its only gonna hold the power that your motor is capable of making(but i highly doubt your stock clutch would slip with the low numbers that are being made), and that throttle body isnt doing shit either unless you can pull lots of air through the intake and flow it out just as fast, 70 is way to big for your motor, air velocity has alot to do with power.....you might be making 180 to the flywheel, and i highly doubt that as well, but i guarantee you dont make 180 to the wheels on a naturally aspirated ls motor with only a built head.......
Huntin Dropa ForLife
you need to put it on the dyno to see where your gears should be set. thats the most effective way
