Check Engine Light After ITR IM Install
Old 05-30-2004, 12:18 PM
Si Punk's Avatar
Si Punk has disabled reputation
Default Check Engine Light After ITR IM Install
Ok well I installed an ITR intake manifold w/ fuel rail and injectors about 3 days ago and have had no problems, runs great. But today, I was driving and noticed my check engine light was on and pulled over and checked what the code was, it was a code 45 (running too rich or lean) and I pretty much figure it's running rich because of the ITR injectors. My question is, will this lead to problems and should I just put the stock b16 injectors in? Thanks
-Jason
Si Punk is offline
Old 05-30-2004, 12:28 PM
hybrid no more :(
Bert's Avatar
Default Re: Check Engine Light After ITR IM Install
ITR injectors are the same size as 00 si injectors... both are 240cc. how's the idle, is it jumpy or is it steady?
Bert is offline
Old 05-30-2004, 03:01 PM
Si Punk's Avatar
Hmm ok well the idle is fine, except for when I just tap the gas. When I just tap it and let it go to like 1.5-2k it comes back down and bogs down almost till it stalls it feels like and then goes back up to like 700 or so.
Si Punk is offline
Old 05-30-2004, 03:37 PM
Unplug your ECU (or pull the ECU fuse) for about half an hour to reset the ECU so it's XRAM is erased, then see how it goes. The ECU needs to relearn with your new bolt-ons..
Old 05-30-2004, 05:29 PM
hybrid no more :(
Bert's Avatar
i would try this too. i can't think of anything else wrong.
Bert is offline
Old 05-30-2004, 06:04 PM
Si Punk's Avatar
ok just did that, unfortunetly after installing the old stock fuel rail and injectors pain in my ass...but yeah we'll see what happans in a half an hour
btw is there any difference between the 00 si and the ITR fuel rails?
Thanks
Si Punk is offline
Old 05-30-2004, 06:31 PM
hybrid no more :(
Bert's Avatar
no difference, all b series 92+ are same.
Bert is offline
Old 05-30-2004, 07:01 PM
Si Punk's Avatar
Ok, straight, thanks a lot. I just plugged the ECU back in and the check engine light went off ran it for about 10 minutes and nothing. So, I think all is well. Thank you guys
Si Punk is offline
Old 06-03-2004, 01:50 PM
Si Punk's Avatar
update
Check Engine Light came back on, I reset the ECU just in case, but I have a feeling my car is running lean. It seems to kinda hesitate when I push on the gas and if I'm at higher RPMs it doesn't feel like it's going as fast as it should. Not sure what to do, any advice would be greatly appreciated, thanks.
Si Punk is offline
Old 06-03-2004, 02:54 PM
Die reinste Bösen.
gear's Avatar
all your vacuum stuff on properly?
gear is offline
Quick Reply: Check Engine Light After ITR IM Install
