87 jeep comanche no ignion and does not start
Old Sep 14, 2007 | 06:07 PM
krazdracer's Avatar
krazdracer has disabled reputation
Default 87 jeep comanche no ignion and does not start
I have a 87 Jeep Comanche 4wd. I just got done replacing the tranny and i go to fire it up and i have absolutely no ignition from the coil. I have 12colts going to it and 5 coming from the ecu. I also definetly have a good ground. I've replaced the ignition control module and the coil with no luck. i don't believe i have any fuel from the injectors either. It ran great before i did the swap and i did not touch anything in the engine compartment since its running. There is a 2 prong connector by the starter that the book says nothing at all about (haynes suck)And i can't find the female connector to match. i'm completely lost anyone??????????
Old Sep 14, 2007 | 06:59 PM
Gustav's Avatar
Gustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these parts
Default Re: 87 jeep comanche no ignion and does not start
If it is a 4.0 liter, check your crank position sensor. It bolts up right at the top of the transmission bellhousing.
Old Sep 15, 2007 | 05:51 AM
krazdracer's Avatar
i will now thnks
boostedgst97
Dec 2, 2009 08:29 AM
krazdracer
Domestic
24
Mar 28, 2008 04:51 AM
Hatchy
Offroad / 4x4 ARCHIVE
12
Oct 15, 2006 07:00 AM
