2000 Corvette Battery Draining - New thread
I'm not sure of the specifics of the Corvette modules, but there are usually test procedures in the service manuals. You'll have to talk to a Corvette guru about that. Most of the time the BCMs are a replaceable part, and aren't usually easy or cost effective to fix, same as an ECU. But don't worry about that much until you actually determine whether that's the culprit or not.
i had the same problem with my dads vette the battery would die after sitting for a day or so but the battery was tested good and so was the alternater . ended up being a bad ground cable that goes from the chassi to the battery. ended up scuffing up the area around the chassi where the cable attaches . fixed the problem. this has happen on two of his vettes.
try this and see if it helps . basically since the ground was bad it was causing it to not recharge right and also casuing it not to have a good ground when you went to start it up . it has been a know problem for many of my friends vettes since the battery is behind the wheel well of the front end on the driver side . when it rain some water might get on the chassi causeing a rust build up or a bad connection for the ground .
early model c5's are notorious for the door control modules going bad.
im crossing my fingers that one of mine dont give out
Thanks again!!!
Originally Posted by RandomTask
C5's have the battery on the passenger side behind the wheel well/coolant overflow. Good theory though.
i orignally had posted it on the passenger side but went back and edited it to the driver side . oppsss
Yup that's me. You guys are great, I take my CLK to Tysinger for everything and never have any problems (except that damned 3rd brake light). Do you still work over there?
update ; just got a voltmeter testing fuses and reattaching ground today will update soon - its not my power seats or courtesy lights; hopefully this thread will help others in the near future lol
