1988 honda prelude help needed
Old 03-10-2013, 05:30 PM
da4door's Avatar
da4door has disabled reputation
I know for civics and crxs are all cable clutches for anything under a 92 but preludes im not sure about
da4door is offline
Old 03-10-2013, 05:36 PM
mtp12389's Avatar
mtp12389 has disabled reputation
Default Re: 1988 honda prelude help needed
@jarret2k
the car was in fine running condition when i bought it. It drove four hours with few problems. One time it would not go into reverse, but only 1 time, after pushing the clutch and trying a second time it worked. No problems shifting or with power. I drove it home and parked it overnight. The next morning I had no clutch pressure and the reservoir was empty. I have located what seems to be a small leak but I am not 100% sure. (ran out of daylight)
mtp12389 is offline
Old 03-10-2013, 05:49 PM
mtp12389's Avatar
ALSO I AM NOT JUST CURIOUS ABOUT THIS PROBLEM. I would like to know suggested engine and transmission swaps for my car
mtp12389 is offline
Old 03-10-2013, 06:06 PM
ConflictedFelon
jarrett2k's Avatar
jarrett2k jarrett2k jarrett2k jarrett2k jarrett2k jarrett2k jarrett2k jarrett2k jarrett2k jarrett2k jarrett2k
Originally Posted by mtp12389
@jarret2k
Reverse on older vehicles is not synched. Hence why it would not go in until after you released the clutch again, "jarring" the car also works. Easy, and probably the cheaper way out is to just take the car to a shop that knows hondas.
jarrett2k is offline
Old 03-10-2013, 07:14 PM
You drove four hours to buy an 88 Prelude?
Old 03-11-2013, 05:48 AM
RandomTask's Avatar
I'm gonna step in here just because the OP seems to be willing to learn and admits he's fairly ignorant. First OP, where are you located?
Next, its obviously leaking fluid somewhere and you need to find out where otherwise you'll be right back in this spot. That said, you need to bleed the clutch, not just put fluid in and pump. You will need a second person to do this without the tools.
You bought a project vehicle, you got a project vehicle. Speaking from years of experience, you NEVER want to make your project vehicle your DD.
Someone who considers it the 'perfect' vehicle.
RandomTask is offline
Old 03-11-2013, 08:41 AM
mtp12389's Avatar
haha yes, it seems I did.
mtp12389 is offline
Old 03-11-2013, 04:56 PM
mtp12389's Avatar
I replaced the slave cylinder and cleared the lines. She drove fine for about 20 min then had a little hick-up shifting (lost clutch pedal pressure) then after hand pumping pedal it returned to an almost better working condition. No leaks to be found other than a small amount near the slave cylinder (prior to replacement)
Is it possible the problem is now in my shifter? Is it possible my pressure issue and shifting issue are not connected? Please do not tell me to "google" this. Google is full of bs and inaccuracy
mtp12389 is offline
Imprtedcivic
Honda
12-26-2010 05:49 PM
SortaFlush
11-07-2010 09:37 AM
Enigma
12-12-2003 12:51 PM
Quick Reply: 1988 honda prelude help needed
