FULLY BUILT ALL MOTOR TYPE R
99' B16 Head (1200 miles)
-Port and polished
-Skunk 2 stage 2 cams
-Skunk 2 high comp valves
-Skunk 2 valve springs
-Skunk 2 retainers
-Skunk 2 intake manifold
-Type R throttle body (62mm)
-RC 310cc injectors
-Golden Eagle cam seal (Brand new)
-AEM V2 cold air intake
-AEM cam gears
-AEM fuel pressure regulator
-AEM fuel rail
-ARP head studs (Brand new)
-Toda Racing head gasket (Brand new)
-Toda Racing timing belt (Brand new)
-DC Sports 4-2-1 ceramic coated header
-Type R JDM red valve cover
98' B18C1 Bottom End (7X,XXX miles)
-CP pistons 11.5 to 1 compression 81mm (Brand new)
-Eagle rods (Brand new)
-AEM pulley kit with belts (Brand new)
-CTR crank pulley (Brand new)
-Type R oil pump (Brand new)
-Type R water pump (Brand new)
-GSR alternator (Brand new)
-Weapon R oil catch can
Type R Tranny (5X,XXX miles)
-4.7 final
-LSD
-2 unknown clutches
-ClutchMasters flywheel
-ACT streetlite flywheel
MISC.
-OBD 2 wire harness
-P28 virgin ecu
-EP3 steering wheel
-EG JDM fog lights
-B16 shift linkage with short shifter
-AutoMeter 5" monster tach (phantom white)
I want $3500(FIRM) for all of it. The whole setup is unassembled except for the head. I might be missing some parts but its all legit. Its not a real type r as you can already tell by reading it but instead its called a poor man's type r. It's a perfect all motor setup to run on pump gas and still be reliable. You can reach me at A300zxluva1020@yahoo.com or my cell (540) 287-2041 if you have any questions! NOT PARTING OUT! Serious inquiries only!!
-Port and polished
-Skunk 2 retainers
-RC 310cc injectors
-AEM cam gears
-AEM fuel rail
-4.7 final
-LSD
-2 unknown clutches
MISC.
-OBD 2 wire harness
-P28 virgin ecu
-EP3 steering wheel
-EG JDM fog lights
