FULLY BUILT ALL MOTOR TYPE R
99' B16 Head (1200 miles)
-Port and polished -Skunk 2 stage 2 cams -Skunk 2 high comp valves -Skunk 2 valve springs -Skunk 2 retainers -Skunk 2 intake manifold -Type R throttle body (62mm) -RC 310cc injectors -Golden Eagle cam seal (Brand new) -AEM V2 cold air intake -AEM cam gears -AEM fuel pressure regulator -AEM fuel rail -ARP head studs (Brand new) -Toda Racing head gasket (Brand new) -Toda Racing timing belt (Brand new) -DC Sports 4-2-1 ceramic coated header -Type R JDM red valve cover 98' B18C1 Bottom End (7X,XXX miles) -CP pistons 11.5 to 1 compression 81mm (Brand new) -Eagle rods (Brand new) -AEM pulley kit with belts (Brand new) -CTR crank pulley (Brand new) -Type R oil pump (Brand new) -Type R water pump (Brand new) -GSR alternator (Brand new) -Weapon R oil catch can Type R Tranny (5X,XXX miles) -4.7 final -LSD -2 unknown clutches -ClutchMasters flywheel -ACT streetlite flywheel MISC. -OBD 2 wire harness -P28 virgin ecu -EP3 steering wheel -EG JDM fog lights -B16 shift linkage with short shifter -AutoMeter 5" monster tach (phantom white) I want $3500(FIRM) for all of it. The whole setup is unassembled except for the head. I might be missing some parts but its all legit. Its not a real type r as you can already tell by reading it but instead its called a poor man's type r. It's a perfect all motor setup to run on pump gas and still be reliable. You can reach me at A300zxluva1020@yahoo.com or my cell (540) 287-2041 if you have any questions! NOT PARTING OUT! Serious inquiries only!! |
