FS: Brand New Sohc vtec honda head gasket
Old Aug 10, 2007 | 03:51 AM
  #21
mrbob1983's Avatar
mrbob1983 has disabled reputation
Default Re: FS: Brand New Sohc vtec honda head gasket
i dont know alot about that kind of stuff but what rods is he using? im not sure how much difference in the height of the pistons is but if you use the correct rods that may fix it, dunno, anyways yeah i got the gasket if he needs it thanks
Old Aug 13, 2007 | 03:37 AM
  #22
mrbob1983's Avatar
Old Aug 14, 2007 | 03:56 AM
  #23
mrbob1983's Avatar
up
Old Aug 15, 2007 | 03:33 AM
  #24
mrbob1983's Avatar
up
Old Aug 16, 2007 | 03:55 AM
  #25
mrbob1983's Avatar
Old Aug 17, 2007 | 04:13 AM
  #26
mrbob1983's Avatar
Old Aug 17, 2007 | 05:13 PM
  #27
99EJ6T's Avatar
Boosted F2B
Originally Posted by XratedSi
Isn't the Y8 gasket thicker than the others?
no, thinner.
Originally Posted by mrbob1983
i didnt think they were any different, if you buy a felpro from advance it says on the package, y7, y8, y5, and i do believe z6, but anyways i bought this for a y8 what do you need it for? Thanks
all d15/d16 blocks can use that HG.
He wants to run vitara pistons in the jdm d15b, the deck height is too short though, someone told him to use a Y8 h/g to correct the thickness and correct the piston to valve clearance issues......i think its a hoax.
depends on the rod used. oem rod will not cause any clearance issues (pin to top is shorter on the vitara vs stock). now the d16 rod... that may cause an issue (134mm rod vs the 137mm rod). but iirc, the difference between the vitaras and stock piston is about 3mm. don't quote me on that though....
btw: oem rod is a big weak point in the engine. so it makes the use of vitaras into a waste of cash, as the amount of possible whp will stay the same.
Old Aug 18, 2007 | 03:29 PM
  #28
mrbob1983's Avatar
Old Aug 20, 2007 | 04:01 AM
  #29
mrbob1983's Avatar
Old Aug 21, 2007 | 10:44 AM
  #30
mrbob1983's Avatar
