FRESH GSR LONG BLOCK, type-r trans, SKUNK 2
Old 11-28-2008, 06:48 AM
got some fake hp
wisepanda's Avatar
wisepanda has a reputation beyond reputewisepanda has a reputation beyond reputewisepanda has a reputation beyond reputewisepanda has a reputation beyond reputewisepanda has a reputation beyond reputewisepanda has a reputation beyond reputewisepanda has a reputation beyond reputewisepanda has a reputation beyond reputewisepanda has a reputation beyond reputewisepanda has a reputation beyond reputewisepanda has a reputation beyond repute
Default FRESH GSR LONG BLOCK, type-r trans, SKUNK 2
CONTACT: 757-537-7728 OR PM
KEEP ALL NEGATIVE COMMENTS TO YOURSELF. UPDATE ******PICS UP*******PRICE DROP
NO TRADES CASH ONLY
Heres the deal, For sale is a fresh, 0 mile GSR motor with the following work done:
All Machine Work was done by Abacus Racing. I have reciepts for all honda parts bought.
I will sell everything listed for $3,100 COmplete longblock with intake manifold, tranny, axles
all you will need is a clutch/flywheel setup,a good header and a ECU andthis setup should make around 215-220 whp
BLOCK: longblock is going for $1800 FIRM
Assembled by Shad at Accuracy Automotive
B18C1, bored 82 mm, decked, honed and hot tanked
ACL standard size rod and main bearings with thrust washers
LS crank, ls rods
Wiseco 12:1 gsr pistons
arp head studs
Gsr crank pulley
gsr oil pan
comes with alternator
black box
water neck/ with thermostat housing
Brand new honda water pump (22T)
Brand new honda timing belt for GSR
Brand new honda Front seal (oil pump)
Brand new honda Rear main seal
Brand new honda oil pan gasket
Brand new honda head gaslet
brand new honda oil filter
Has driver side mount for EK on it
HEAD:
2000 gsr head with the following machine work done:
Decked (just a resurface of a couple thousandths)
Valves re cut and brand new honda valve stem seals
It is a Stock port head
has Skunk 2 valve springs and retainers
BLOX pro 1 cams (BRAND NEW NEVER RUN)
BRAND NEW PRO SERIES SKunk 2 cam gears
Golden Eagle Cam plug on v-tec solenoid side
comes with solenoid (missing oil pressure switch plug)
HONDATA intake manifold gasket
Brand new honda valve cover gasket/with 4 spark plug
Brand new honda valve cover grommets (silver/crome)
Brand new honda spark plug wires
Brand new honda cam seals
Brand new honda timing belt covers
Brand new honda timing belt cover bolts
Brand new honda valve cover bolts (10 mm)
Brank new NGK 7's
Valve Cover is a GSR that i stripped preped and sprayed wrinkle red (looks just like a type-rrrrr)
I moon cut the valve cover and upper timing belt cover
00 b16 Distributor with new o-ring gasket, honda cap and rotor button
Will sell the manifold with throtlle body for $400 FIRM
Skunk 2 pro series Intake manifold (BRAND NEW)
Ported out to 70 mm on the throttle body side
comes with IAC ALSO $250 firm
Skunk 2 70mm throttle body (slightly used)
with TPS/ NO map. All hardware/no gasket $200
TRANS: $900 FIRM
Type-r trans
Bought this trans from a friend
Shad pulled the trans apart and looked at it and put a third gear syncro in it and said everything else looked fine.
I have since gave it a acid bath and put brand new honda axle seals in it
looks mint.
The only problem is i can't tell you what year trans it is because the vin plate is not on it, so i dont know what the final drive is.
AXLES: $100 FIRM
2 brand new b series axles bought from napa
still in packaging
si shift linkage with shifter will also come with sale if buyer wants
i also have a bottom timing belt cover for a b16, brand new OEM. still in packaging. 20 FIRM
wisepanda is offline
Old 11-28-2008, 07:03 AM
da dragva kokopelli
mike nagz's Avatar
Default Re: FRESH GSR LONG BLOCK, type-r trans, SKUNK 2
damn tim.
changed your plans?
gl with sale.
this shit is MINT. i will vouch.
mike nagz is offline
Old 11-28-2008, 07:06 AM
got some fake hp
wisepanda's Avatar
Originally Posted by hang the nagger
damn tim.
changed your plans?
gl with sale.
a house is more important right now for me. the extra cash will help out.
i will put something in my car SOMEDAY THis is the second motor i have built for this car and neither one saw my engine bay.
..... oh well
Old 11-28-2008, 07:20 AM
da dragva kokopelli
mike nagz's Avatar
..... oh well
yeah same reasons im getting rid of the coupe.
gl bro.
Old 11-28-2008, 07:39 AM
27psi???'s Avatar
27psi??? has disabled reputation
good deal bump
27psi??? is offline
Old 11-28-2008, 07:41 AM
HighestTraderRating
ant*'s Avatar
I want that intake mani and tb.
Bump for nice build n good price.
ant* is offline
Old 11-28-2008, 07:54 AM
got some fake hp
wisepanda's Avatar
^^ pmed
Old 11-28-2008, 03:07 PM
braap braap
Jarrod's Avatar
House>*
Also, will vouch for the power it WILL make. It will need a nice header and a good tune(i.e. SHAD) to make the power.
Wish my brother had the loot.
Jarrod is offline
Old 11-28-2008, 03:25 PM
Don't envy my idle
hondaintegra757's Avatar
hondaintegra757 has disabled reputation
will vouch for this CLEANNNNNN ass motor set up, if i had the money i would put it in my car in a heart beat...
Someone needs to grab this great deal asap!!!
hondaintegra757 is offline
Old 11-28-2008, 05:04 PM
NO DUH's Avatar
NO DUH NO DUH NO DUH NO DUH NO DUH NO DUH NO DUH NO DUH NO DUH NO DUH NO DUH
will also vouch for tim and the this motor was put together right and as clean as a brand new motor from honda would be..
damn tim sux that it wont make it into your car but its alright since your car is still mint..
glwts
someone buy this mans stuff you could possibly get a better deal on this stuff.
NO DUH is offline
Quick Reply: FRESH GSR LONG BLOCK, type-r trans, SKUNK 2
