FRESH GSR LONG BLOCK, type-r trans, SKUNK 2
LOCATION: SUFFOLK, VA CONTACT: 757-537-7728 OR PM KEEP ALL NEGATIVE COMMENTS TO YOURSELF. UPDATE ******PICS UP*******PRICE DROP NO TRADES CASH ONLY Heres the deal, For sale is a fresh, 0 mile GSR motor with the following work done: All Machine Work was done by Abacus Racing. I have reciepts for all honda parts bought. I will sell everything listed for $3,100 COmplete longblock with intake manifold, tranny, axles all you will need is a clutch/flywheel setup,a good header and a ECU andthis setup should make around 215-220 whp BLOCK: longblock is going for $1800 FIRM Assembled by Shad at Accuracy Automotive B18C1, bored 82 mm, decked, honed and hot tanked ACL standard size rod and main bearings with thrust washers LS crank, ls rods Wiseco 12:1 gsr pistons arp head studs Gsr crank pulley gsr oil pan comes with alternator black box water neck/ with thermostat housing Brand new honda water pump (22T) Brand new honda timing belt for GSR Brand new honda Front seal (oil pump) Brand new honda Rear main seal Brand new honda oil pan gasket Brand new honda head gaslet brand new honda oil filter Has driver side mount for EK on it HEAD: 2000 gsr head with the following machine work done: Decked (just a resurface of a couple thousandths) Valves re cut and brand new honda valve stem seals It is a Stock port head has Skunk 2 valve springs and retainers BLOX pro 1 cams (BRAND NEW NEVER RUN) BRAND NEW PRO SERIES SKunk 2 cam gears Golden Eagle Cam plug on v-tec solenoid side comes with solenoid (missing oil pressure switch plug) HONDATA intake manifold gasket Brand new honda valve cover gasket/with 4 spark plug Brand new honda valve cover grommets (silver/crome) Brand new honda spark plug wires Brand new honda cam seals Brand new honda timing belt covers Brand new honda timing belt cover bolts Brand new honda valve cover bolts (10 mm) Brank new NGK 7's Valve Cover is a GSR that i stripped preped and sprayed wrinkle red (looks just like a type-rrrrr) I moon cut the valve cover and upper timing belt cover 00 b16 Distributor with new o-ring gasket, honda cap and rotor button Will sell the manifold with throtlle body for $400 FIRM Skunk 2 pro series Intake manifold (BRAND NEW) Ported out to 70 mm on the throttle body side comes with IAC ALSO $250 firm Skunk 2 70mm throttle body (slightly used) with TPS/ NO map. All hardware/no gasket $200 http://i95.photobucket.com/albums/l1...msmotor006.jpg http://i95.photobucket.com/albums/l1...msmotor005.jpg http://i95.photobucket.com/albums/l1...msmotor007.jpg http://i95.photobucket.com/albums/l1...msmotor008.jpg http://i95.photobucket.com/albums/l1...msmotor011.jpg http://i95.photobucket.com/albums/l1...msmotor014.jpg TRANS: $900 FIRM Type-r trans Bought this trans from a friend Shad pulled the trans apart and looked at it and put a third gear syncro in it and said everything else looked fine. I have since gave it a acid bath and put brand new honda axle seals in it looks mint. The only problem is i can't tell you what year trans it is because the vin plate is not on it, so i dont know what the final drive is. http://i95.photobucket.com/albums/l1...msmotor002.jpg http://i95.photobucket.com/albums/l1...msmotor003.jpg AXLES: $100 FIRM 2 brand new b series axles bought from napa still in packaging http://i95.photobucket.com/albums/l1...msmotor013.jpg si shift linkage with shifter will also come with sale if buyer wants i also have a bottom timing belt cover for a b16, brand new OEM. still in packaging. 20 FIRM |
Re: FRESH GSR LONG BLOCK, type-r trans, SKUNK 2
damn tim.
changed your plans? gl with sale. this shit is MINT. i will vouch. |
Originally Posted by hang the nagger
(Post 4746078)
damn tim.
changed your plans? gl with sale. this shit is MINT. i will vouch. i will put something in my car SOMEDAY:( THis is the second motor i have built for this car and neither one saw my engine bay. ..... oh well |
Originally Posted by wisepanda
(Post 4746082)
a house is more important right now for me. the extra cash will help out.
i will put something in my car SOMEDAY:( THis is the second motor i have built for this car and neither one saw my engine bay. ..... oh well gl bro. |
good deal bump
I want that intake mani and tb.
Bump for nice build n good price. |
^^ pmed
House>*
Also, will vouch for the power it WILL make. It will need a nice header and a good tune(i.e. SHAD) to make the power. Wish my brother had the loot. :mad: |
will vouch for this CLEANNNNNN ass motor set up, if i had the money i would put it in my car in a heart beat...
Someone needs to grab this great deal asap!!! |
will also vouch for tim and the this motor was put together right and as clean as a brand new motor from honda would be..
damn tim sux that it wont make it into your car but its alright since your car is still mint.. glwts someone buy this mans stuff you could possibly get a better deal on this stuff. |
