ACT StreetLite XACT Flywheel dsm
Sold my car a few years ago and ran across this in my garage.. Its never been used, I installed it and it didnt fit my car.(starter was about 2" away, incorrect model for my car). . Please search the model number to ensure it will fit your car..
$200.00
Steve 757 592 7872
Ntinhri@aol.com
ACT StreetLite XACT Flywheel Eagle Talon 1989-1992
ACT StreetLite XACT Flywheel Eagle Laser 1989-1992
ACT StreetLite XACT Flywheel Mitsubishi Eclipse 1989-1992
ACT StreetLite XACT Flywheel Mitsubishi Galant 1991-1992
SKU: ACT-600150 (2784)
MSRP: $342.77
ACT XACT flywheels provide significantly improved engine response, acceleration and a higher degree of safety than the original stock flywheels. All ACT XACT flywheels feature a super rigid, trouble free single piece design. This one piece design allows less opportunity for failure and provides for uniform and efficient heat transfer from the clutch, eliminating warped inserts and loose ring gears. ACT XACT flywheels are precisely made using chromoly forgings, also known as chromium-molybdenum steel, a metal which is three times more rigid than aluminum. The materials on ACT XACT flywheels are properly distributed for maximum strength, lower inertia and good heat tolerance. In addition, ACT heat-treats their flywheel forgings for strength and induction-hardens their ring gears for the longest gear life. ACT XACT flywheels are easily serviceable and can be resurfaced without the need to purchase additional parts. All ACT XACT flywheels are SFI certified to meet proper safety measures.
ACT XACT StreetLite flywheels are lighter and stronger than stock cast flywheels and are designed to improve driveability and durability. These super rigid flywheels are precision made using high-tech CNC equipment and computer balanced for super smooth high RPM reliability. ACT XACT StreetLite flywheels are recommended for both Street and Drag Racing.
Key Features:
- Quicker acceleration and increased throttle response
- Maximum gear life – gear will not wear out or fall off
- Serviceable – can be resurfaced with no need to purchased additional parts
- Chrome-moly forgings three times more rigid than aluminum
- Longer lasting because of heat treated friction surfaces
- Excellent heat capacity from retaining adequate material behind the friction surface
- Super rigid trouble-free single piece design
- SFI certified to insure safety
Reference: ACT XACT StreetLite Flywheel, ACT XACT Flywheel, ACT StreetLite Flywheel, Advanced Clutch Technology StreetLite XACT Flywheel
APPLICATION: ACT StreetLite XACT Flywheel Eagle Talon 1989-1992
PRODUCT NOTES: Turbo AWD / 6 Bolt
$200.00
Steve 757 592 7872
Ntinhri@aol.com
MSRP: $342.77
Key Features:
