89mm B18B/B20 *Knife-edged* *Micro-Polished* Crankshaft Crank
Old Nov 11, 2008 | 12:31 PM
  #21
p2r's Avatar
p2r
!! Buy My Parts !!
p2r has disabled reputation
Default Re: 89mm B18B/B20 *Knife-edged* *Micro-Polished* Crankshaft Crank
Old Nov 12, 2008 | 12:24 PM
  #22
p2r's Avatar
p2r
!! Buy My Parts !!
Old Nov 13, 2008 | 08:14 AM
  #23
p2r's Avatar
p2r
!! Buy My Parts !!
Old Nov 14, 2008 | 10:47 AM
  #24
p2r's Avatar
p2r
!! Buy My Parts !!
Old Nov 17, 2008 | 04:00 AM
  #25
p2r's Avatar
p2r
!! Buy My Parts !!
Old Nov 17, 2008 | 05:22 AM
  #26
DeFunk's Avatar
DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk
Eagle Stroker kits ARE garbage, enough said. Eagle's import products suck period, but that's for another thread in a totally different forum/category. Can't believe people compared a LS crank to an Eagle. Sad.
Old Nov 17, 2008 | 06:01 AM
  #27
p2r's Avatar
p2r
!! Buy My Parts !!
I can agree.
Old Nov 17, 2008 | 06:07 AM
  #28
p2r's Avatar
p2r
!! Buy My Parts !!
Just some more info - in the event you need it
Originally Posted by xeno
yo the crank cant be for b18b and b20 man... unless the b18b was bored out and you used the b20 crank on it..? b20 crank is bigger because its a bigger dis. than a b18 the rods are longer also..
Actually -
the only difference between the B18B and B20 is the bore. Piston diameter on the B18B is 81mm, whereas the B20 is a 84mm bore.
This has Nothing to do with the STROKE though - which is 89mm on both the B18B and B20. And they Also use the same Rods.
That being said. The difference between a B18C and a B18B (as per the displacement) is the Crank. Both have 81mm bore (pistons diameter) but the B18C uses a 87mm stroke, not 89mm like the B18B/B20. This is where you'd get the extra 50cc in the LSVtec application.
If you have any more questions/comments/concerns lmk. I've been building these motors for years, so I know what works.
-Justin
Old Nov 17, 2008 | 11:36 AM
  #29
p2r's Avatar
p2r
!! Buy My Parts !!
......bump......
Old Nov 18, 2008 | 04:54 AM
  #30
p2r's Avatar
p2r
!! Buy My Parts !!
going out of town..
catch up with you soon -
