TONS of Eclipse Turbo Parts
I have 3 turbo dsm cars I am parting out
Following parts are from a 1992 Mitsubishi eclipse GST:
complete 6 bolt motor from valve cover to oil pan- 450
1g rebuilt head-hot tanked clean w/ cams and cam gears ready to bolt on!-250
1g head in good condition w/ cams and cam gears ready to bolt on and go!-200
1g FWD turbo tranny-200
6 bolt block with crank-100
1 set of 6 bolt rods-35
3 6 bolt pistons-10 each (replace a blown piston for CHEAP!!)
5 intake manifolds-15 each
alternator-30
cruise control-30
ps pump-35
1g fwd axles in good shape-30
3 1g fuel rails w/ regulators-15 each
1g waterpump-20
1g coilpack-20
1g cas-20
2 1g oil filter housings-15
1g shifter cables(good for auto to manual swap)-15
single piston front calipers-20 each
1gb turbo eclipse front bumper--replace that hacked up front bumper with this great shape bumper!-35
1gb eclipse rear tails w/ center section-30
1g waterneck-10
1g smic-15
3 piece turbo wing-35
1g fog lights w/ brackets-25
Following parts are from a 1996 Mitsubishi eclipse GST:
2g stock head with cams and cam gears--ready to bolt on and go! 200
2g pistons on 2g rods-40
2 2g front case with oil pump-20
3 2g oil filter housing-20
2 7 bolt bare blocks(crank walked, but can include crank--great for a rebuild)-make offer
FWD turbo tranny locked in 3rd I believe--use the case or parts or rebuild and sell/ use-make offer
2g Non-Eprom ECU-80
White 3 piece low rise wing-35
single piston front brake calipers-20 each
double piston brakes w/ brackets-70 for set
drilled front rotors-20
ALL AC components--put your AC back together!!!-40 for everything!!!
2 alternators-30 each
starter-30
2 water pumps-20 each
2 2g coil packs-20 each
stock radiator fans-15
stock infinite amp w/ stock cable!!-20
2 stock clutches-25 each
fuel rail w/ reg-15
7 bolt flywheel-15
2ga eclipse taillights with center section in GREAT shape-40
2g 2ga headlights (one is foggy)- best offer
2g cruise control, everything you need-30
2 2g TB elbows-15
2g tranny mounts/ motor mount-35 for set
2g doors with no panel--comes with power windows/ locks-30 each (driver door has crack in handle--easy and cheap fix for GREAT doors if yours are dented/ rusted)
2g front hubs with knuckles-20 each
2g strut tower brace-30
2g fwd weapon r coilovers-40 for set
2g injen fuse box lid- 30
Parts from a 1992 tsi awd turbo:
6 bolt block/ crank- 100
awd manual tranny-250
6 bolt rods-35
recently rebuilt 6 bolt head- 225
t-case-60
front case-30
transistor-15
interior pieces- best offer
front and back seats- best offer
turbo gauge cluster- 15
1gb talon front/ rear bumpers-75
1gb hood-40
1gb headlights-30
1gb fenders-30 each
1gb tsi 3 piece tail lights-45
hatch struts that aren't blown-25
14b turbo in good condition-100
resistor pack-20
tb with all sensors-35
cas-20
o2 housing-15
1g exhaust mani-20
intake mani-15
vc-30
coil pack-25
1g bov uncrushed-30
stock springs/ shocks-35
driveshaft-35
engine harness-80
power steering pump/ lines-30
ac-25
alternator-30
alternator with 500 miles on it-50
starter-30
6 bolt flywheel-20
motor mounts-35
90-92 federal automatic awd non-eprom ecu-65
radiator w/ fans-35
Anything else you can think of that you don't see posted, just ask. I probably have it.
Rear, big brakes, rear brakes all sold already.
Here are some parts that are non-year specific:
4 valve covers-30 each
Pioneer6x9's--look new--30
Sony xPlode 6x9's-30
aftermarket oil feed line-15
17" ADR Rims-150
16 valves in good shape-buy just one to replace a broke valve without paying the expense of buying new ones!-4 each, or 30 for them all.
3 timing belt covers- 10 each
***REAL greddy type s bov- 135
IF YOU DON'T SEE IT, ASK! I have MANY parts lying around my garage which may not be listed. Thanks
alternator-30
cruise control-30
ps pump-35
1g waterpump-20
1g coilpack-20
1g cas-20
1g waterneck-10
1g smic-15
2g Non-Eprom ECU-80
starter-30
fuel rail w/ reg-15
7 bolt flywheel-15
2 2g TB elbows-15
6 bolt rods-35
t-case-60
front case-30
transistor-15
1gb hood-40
1gb headlights-30
1gb fenders-30 each
resistor pack-20
cas-20
o2 housing-15
1g exhaust mani-20
intake mani-15
vc-30
coil pack-25
1g bov uncrushed-30
driveshaft-35
engine harness-80
ac-25
alternator-30
starter-30
6 bolt flywheel-20
motor mounts-35
radiator w/ fans-35
17" ADR Rims-150
Re: TONS of Eclipse Turbo Parts
location? and pm me details on the 92 fwd trans.
i <3 my neon
wouldnt happen to have tan seats for a 2nd gen would you?
Could you pm or give me a call or text if i can come get one of the biss screws and o ring from one of the 1st gen manifolds asap. 7572983250
pm me pics of the 17's and if you happen to have a rear bumper thatll fit my 98 eclipse i need that too
20g turbo? if you have it pm me because i probably wont check this thread agian
2g injen fuse box lid- 30 i will buy off you and im looking for the horns and a battery tray with the hold down hardware if you have them. pm the details. i have a 95 gst
