TONS of Eclipse Turbo Parts
I have 3 turbo dsm cars I am parting out
Following parts are from a 1992 Mitsubishi eclipse GST: complete 6 bolt motor from valve cover to oil pan- 450 1g rebuilt head-hot tanked clean w/ cams and cam gears ready to bolt on!-250 1g head in good condition w/ cams and cam gears ready to bolt on and go!-200 1g FWD turbo tranny-200 6 bolt block with crank-100 1 set of 6 bolt rods-35 3 6 bolt pistons-10 each (replace a blown piston for CHEAP!!) 5 intake manifolds-15 each alternator-30 cruise control-30 ps pump-35 1g fwd axles in good shape-30 3 1g fuel rails w/ regulators-15 each 1g waterpump-20 1g coilpack-20 1g cas-20 2 1g oil filter housings-15 1g shifter cables(good for auto to manual swap)-15 single piston front calipers-20 each 1gb turbo eclipse front bumper--replace that hacked up front bumper with this great shape bumper!-35 1gb eclipse rear tails w/ center section-30 1g waterneck-10 1g smic-15 3 piece turbo wing-35 1g fog lights w/ brackets-25 Following parts are from a 1996 Mitsubishi eclipse GST: 2g stock head with cams and cam gears--ready to bolt on and go! 200 2g pistons on 2g rods-40 2 2g front case with oil pump-20 3 2g oil filter housing-20 2 7 bolt bare blocks(crank walked, but can include crank--great for a rebuild)-make offer FWD turbo tranny locked in 3rd I believe--use the case or parts or rebuild and sell/ use-make offer 2g Non-Eprom ECU-80 White 3 piece low rise wing-35 single piston front brake calipers-20 each double piston brakes w/ brackets-70 for set drilled front rotors-20 ALL AC components--put your AC back together!!!-40 for everything!!! 2 alternators-30 each starter-30 2 water pumps-20 each 2 2g coil packs-20 each stock radiator fans-15 stock infinite amp w/ stock cable!!-20 2 stock clutches-25 each fuel rail w/ reg-15 7 bolt flywheel-15 2ga eclipse taillights with center section in GREAT shape-40 2g 2ga headlights (one is foggy)- best offer 2g cruise control, everything you need-30 2 2g TB elbows-15 2g tranny mounts/ motor mount-35 for set 2g doors with no panel--comes with power windows/ locks-30 each (driver door has crack in handle--easy and cheap fix for GREAT doors if yours are dented/ rusted) 2g front hubs with knuckles-20 each 2g strut tower brace-30 2g fwd weapon r coilovers-40 for set 2g injen fuse box lid- 30 Parts from a 1992 tsi awd turbo: 6 bolt block/ crank- 100 awd manual tranny-250 6 bolt rods-35 recently rebuilt 6 bolt head- 225 t-case-60 front case-30 transistor-15 interior pieces- best offer front and back seats- best offer turbo gauge cluster- 15 1gb talon front/ rear bumpers-75 1gb hood-40 1gb headlights-30 1gb fenders-30 each 1gb tsi 3 piece tail lights-45 hatch struts that aren't blown-25 14b turbo in good condition-100 resistor pack-20 tb with all sensors-35 cas-20 o2 housing-15 1g exhaust mani-20 intake mani-15 vc-30 coil pack-25 1g bov uncrushed-30 stock springs/ shocks-35 driveshaft-35 engine harness-80 power steering pump/ lines-30 ac-25 alternator-30 alternator with 500 miles on it-50 starter-30 6 bolt flywheel-20 motor mounts-35 90-92 federal automatic awd non-eprom ecu-65 radiator w/ fans-35 Anything else you can think of that you don't see posted, just ask. I probably have it. Rear, big brakes, rear brakes all sold already. Here are some parts that are non-year specific: 4 valve covers-30 each Pioneer6x9's--look new--30 Sony xPlode 6x9's-30 aftermarket oil feed line-15 17" ADR Rims-150 16 valves in good shape-buy just one to replace a broke valve without paying the expense of buying new ones!-4 each, or 30 for them all. 3 timing belt covers- 10 each ***REAL greddy type s bov- 135 IF YOU DON'T SEE IT, ASK! I have MANY parts lying around my garage which may not be listed. Thanks |
Re: TONS of Eclipse Turbo Parts
location?
location? and pm me details on the 92 fwd trans.
Location I need a couple of things
wouldnt happen to have tan seats for a 2nd gen would you?
Yea, location? I need the 1g TB. Let me know.
Could you pm or give me a call or text if i can come get one of the biss screws and o ring from one of the 1st gen manifolds asap. 7572983250
pm me pics of the 17's and if you happen to have a rear bumper thatll fit my 98 eclipse i need that too
20g turbo? if you have it pm me because i probably wont check this thread agian
2g injen fuse box lid- 30 i will buy off you and im looking for the horns and a battery tray with the hold down hardware if you have them. pm the details. i have a 95 gst
