help...easiest way for 35's
Old Mar 23, 2009 | 07:59 PM
B-Well's Avatar
I Love to Hate
Default Re: help...easiest way for 35's
Originally Posted by BradEK
if you want to get a lift then
i think rough country is the cheapest but im not positive
and those body styles are great for tire clearance so you might be able to get it with 3 inches
and shittiest.
I'm a wrangler guy and untill just recently everything they've produced has sucked balls. Complete lifts with all new leaf packs that sag, not talking add a leaf here, all new leafs, assembled by RC that sag a bunch
Old Mar 24, 2009 | 05:12 PM
SJK's Avatar
SJK
SJK is on a distinguished road
Originally Posted by B-Well
and shittiest.
thats good to know, is pro comp lift kits pretty good? or does anybody know any other company thats decent?
Old Mar 24, 2009 | 06:02 PM
ShortyzKustomz's Avatar
Anti "DONK"
ShortyzKustomz has disabled reputation
x2 on Yota tech, I used that site ALOT on building my engine and everything, Them and Pirate 4x4...But then again they will tell you to save for a SAS
My old Yota, You can see I had more room to play with on 32s and 3 inch BL
(I know its an 84-88, But its got a 92 Bed)
Old Mar 24, 2009 | 06:09 PM
BradEK's Avatar
no vtec ftw
BradEK is a name known to allBradEK is a name known to allBradEK is a name known to allBradEK is a name known to allBradEK is a name known to allBradEK is a name known to all
and shittiest.
yea i was never a fan of it its just a quick and cheap way
i was always a fan of skyjacker and brands of that sort
Old Mar 25, 2009 | 01:16 PM
SJK's Avatar
SJK
looks pretty good. body lift may be a possibility but leaning more towards just suspesion lift
Old Mar 25, 2009 | 01:24 PM
SJK's Avatar
SJK
I want to do it right the first time.
I've been looking around, found this lift kit for $840. anybody ever had a lift by "Superlift," and does anybody know if I can get a lift for less...
http://ultimateautoaccessories.com/p...source=Froogle
Old Mar 25, 2009 | 01:26 PM
JDM74's Avatar
JDM74 JDM74 JDM74 JDM74 JDM74 JDM74 JDM74 JDM74 JDM74 JDM74 JDM74
Are you re-gearing with the 35's? The cheapest lift is going to be Cranking torsion bars + ball joint spacer, 1" body lift and add-a-leafs in the rear. With this you are still going to have to do some triming (you won't be able to tell unless you look in the wheel wells) and pound the body seam flat on the back of the front wheel wells.
Prepare for a un-useable 5th gear. I run 33's on a 1" body lift, cranked torsion bars and add-a-leafs in the rear. Truck has 4.56 gears and a aussie locker and other goodies.
Old Mar 25, 2009 | 01:34 PM
SJK's Avatar
SJK
thats looks like a decent setup with the 33's. Might be the anwser. Thanks. How well does suspension lift+body lift work out if I would like to add more lift or bigger tires?
Old Mar 25, 2009 | 02:24 PM
JDM74's Avatar
With the torsion bars cranked up and the ball joint spacers you are at the limit of "cheap" IFS lift. The next step is a bracket lift which is a lot more expensive. I personally would not go any higher than a 1" body lift. Too much headache with other little things and too much leaverage on the body mounting bolts. If my truck gets any more suspension work or lift it will be with a SAS.The front IFS is just too week to support a bigger tire than what I am running right now.
Old Mar 25, 2009 | 07:23 PM
Anti "DONK"
Well maybe my factory gearing was better I used 5th gear fine on 32s and 33s on mine, Even held 5th gear half way up Afton mountain on 32s
