First time mudding in my truck...
Old Aug 3, 2007 | 07:37 PM
1qikcoupe's Avatar
1qikcoupe has disabled reputation
Default Re: First time mudding in my truck...
Originally Posted by ChevyMudtruck
yes must say th400 is the shit . . . but got to get the right adapter and t-case to go to it though cuz one behind a th350 won't work . . . . broke 2 th350's and now have a th400 and going strong . . holding up pretty well to my big block
this is my current prob though
damn flexplates are over rated anyhow
damn right!!
Old Aug 3, 2007 | 10:34 PM
tommasiphotos's Avatar
tommasiphotos has disabled reputation
sweet thanks. its all up to a toyota t-case.
Old Aug 4, 2007 | 06:11 AM
ChevyMudtruck's Avatar
just a little 4x4
ChevyMudtruck ChevyMudtruck ChevyMudtruck ChevyMudtruck ChevyMudtruck ChevyMudtruck ChevyMudtruck ChevyMudtruck ChevyMudtruck ChevyMudtruck ChevyMudtruck
hmmm wounder if there is some kinda spline adapter or what . . . the th350 has a 4 bolt tailshaft and a 27 spline output shaft while the th400 is a 6 bolt circluar tailshaft bolt pattern with a 32 spline output . . . they may make and adapter to a yota t-case but not sure . . what side drop is the yota case?
Old Aug 4, 2007 | 11:43 AM
pass. side
Old Aug 4, 2007 | 03:16 PM
just a little 4x4
pass. side
that means technically you could run a chevy t-case to . . don't know how that would effect your driveshaft lengths and crossmember though . . not sure how bullit poof the yota t-cases are . . . but could ended up with a th400 with a np203 . . but the 203 is pretty heavy . . . 197 pounds with no fluid I believe . .. or th400 or np205 which sould be an awsome combo but again the np205 is cast iron and heavy . . . I believe in the mid - late 80's they put the th400 infront of the np208 but not sure why cuz it's an alluminum t-case and not the strongest but however did run em in the military hummers and stuff . . .
chevyman16
Mar 2, 2007 09:41 AM
10seclx
Jan 26, 2007 03:13 PM
Saltydog
Offroad / 4x4 ARCHIVE
Sep 10, 2006 05:06 PM
myS10
Feb 26, 2006 05:46 PM
myS10
Feb 23, 2006 07:20 PM
