93 civic lx 4door *BUILT*
Old Dec 18, 2008 | 02:47 PM
  #21
cjsass's Avatar
Killa VBeez
cjsass has disabled reputation
Default Re: 93 civic lx 4door *BUILT*
Old Dec 18, 2008 | 03:02 PM
  #22
gsr-turd's Avatar
h22 POWA
gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd
Originally Posted by cjsass
justin
757-714-1938
va beach
price 5500 obo
ok so i just got this car in a trade about 2 months ago from (madsteez) i like the car i just got it at a bad time in my life and really need money right now so i would like to sell outright for 5500 obo or i am accepting trades plus cash for your DD or straight trades if they are worth it
NO PRIMERED BEATERS OR SHAT BOXES....
The car is a 1993 honda civic lx. It has all power options such as windows,locks,mirrors,ps, There is about 172,000 on the car its self and about 2100-2400 on the motor......here is the mods list from previous owner
Suspension:
-Skunk 2 pro series fully adjustable coilovers/struts.
-Skunk 2 front upper ball joint/camber kit.
-Ingalls rear camber kit.
-new front lower control arm bushings
-Skunk 2 annodized silver rear lower control arms.
-Slotted front rotors and akebono front brake pads all oem equipment in rear.
Interior:
-Integra gsr tan cloth front seats,stock rear seats.
-Pioneer headunit.
-Pioneer front speakers.
-Sony explod rear speakers.
-Short shifter-blue along with blue shift knob.
-keyless entry/alarm
Exterior:
-Color matched side modlings.
-Color matched folding mirrors.
-Partially shaved trunk done by dreamworks.
-Front bumper is partially cut for intercooler
-Touch up paint on some areas.
-15in work RS beta knock offs (rotas the infamous knock off wheel)
-Stanley amber corners.
-mugen style front lip(just installed last week)
Drivetrain:
-98 Integra Type r transmission with lsd and 4.7 final drive
-Hasport motor mounts
-Clutch Masters stage 4 6 puck sprung clutch
-8 lb flywheel
-Axles from a 2000 civic si
-Password JDM shift bushings
Engine:
The bottom end was built by Abacus in va beach
-95 b18c1 block 81.5mm bore
-Eagle H beam connecting rods
-Cp 11.5:1 high compression pistons
-All acl Bearings
-Arp head studs
-Brand new Type R oil pump
-Brand new Type R waterpump
-Brand new Type R timing belt and tensioner
-Brand new front crank seal
-Brand new main seal
-Password jdm magnetic oil drain bolt
The cylinder head was assembled by Jaysen from Force Fed Air in Florida
-99 B16A2 Head
-RLZ Ported and Mild Polish (shiny polishing sucks for air/fuel mixture)
-Skunk 2 stage 2 tuner cams(as of now it has gsr cams.will have new skunk 2s soon)
-SuperTech Inconel Exhaust Valves
-SuperTech Black Nitraded Intake Valves
-5 Angle Valve "Job"
-PortFlow Inner/Outer Spring Set
-PortFlow Titanium Retainers
-Manley Hardened Steel Retainers
-Golden Eagle 3 ring cam seal
-Hondata intake manifold gasket
-Stock distributor with new cap and rotor
-AEB's polished intake manifold
-Type R throttle body and all other sensors
-DSM 450cc injectors from a ford lightning.
Tuned on crome at dyno inc in va beach and is making 212whp to the wheels on a dyno jet.
(with skunk 2 cams)
Exhaust:
-97 itr header
-2 1/2 inch piping flowing directly into a magnaflow stock appearence muffler.
-high flow cat
BAD:
-couple of small dents and dings just from rocks and shit.
-no ac have most componets though
I may be missing some things but that about sums it up.heres some pics!!!
http://s307.photobucket.com/albums/nn302/cjsass/
sounds like a good car and nice build. but isn't dyno inc. a mustang dyno? 212 on dyno jet?
also confused alittle with the on skunk 2 cams. your post says it has gsr cams?
thanks.
Old Dec 18, 2008 | 05:30 PM
  #23
madsteez's Avatar
Ohhh Snap
madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez
made 198 on dyno inc's
so on a dyno jet itll make anywhere from 212-225.
When I had it I ran a 226 whp k swapped hatch and stayed neck and neck till my gsr tranny got the worst of me.
It had Skunk 2 cams,one cam broke so I put in the GSR's. When it had the Skunk 2's and the mint Type r trans I do not know of a quicker all motor car in the area.
As for Levi,that car was in horrible shape when I got it,it barely ran with the sohc,the interior was spray painted,needed rear brakes BAD,everything except for the seats and dash I put in. Everything under the hood and the exhaust is from me.New engine harness,had ac till the line dragged on the ground.
Sasser did you fix 3rd gear yet?
Old Dec 18, 2008 | 06:18 PM
  #24
cjsass's Avatar
Killa VBeez
i have an exedy stage 1 clutch to replace the clutch masters one thats going bad...fransisco is gonna fix it i have already talked to him about it i just have to work around his busy schedule....thats why 3rd gear grinds in high rpms its not the synchros!!!!!! i didnt list that cuz it will be fixed befor sale or trade!!!!!!!!!!!! hopefully this weekend
and thanks for clarifying that .........and i will be getting the skunk 2 cams back as soon as i get paid (tuesday) so it will be back to how it was............any other questions???
and btw its only grinded for me 3 times and i have been driving it everyday
Old Dec 18, 2008 | 07:32 PM
  #25
idriveahonda's Avatar
Shooting 63's
Dude, read what I wrote. I referenced the person BEFORE you, and AFTER me.
Silly twat. A single owner (who only had it for like 3 months) was a complete fucking retard ricer, who fucked up an engine that I had no problems with from the 4 years I owned it. Madsteez got tired of the single cam, and replaced the motor with whats in it now, and had to replace the interior because dumbass repainted it before him.
So it went like this:
Me (idriveahonda, mr.jennabliss) - original builder from stock, exterior, interior, motor setup, suspension...all mint
Jimmy - fucked up the first motor, riced out the interior by painting, and fucked up the exterior which he replaced with a shit hood
Madsteez - had to fix what shithead above had done, went through a bazillion single cams, and then put the motor thats in there, new interior, and cleaned it back up
If steez has anything to add from his horrible experience from that single owner, he'll add it.
But gives you good information on the car!
Old Dec 18, 2008 | 08:03 PM
  #26
cjsass's Avatar
Killa VBeez
word well either way if my nissan sells this weekend im gonna keep the civic cuz i do really like it i just owe my lawyer 2200 by a week and a half from now.. and i dont have that cash laying around... and yes the hood is not perfect its gotten really hot from a turbo set up from what it looks to me and the metal under the hood is coming apart from the actual hood.....i dont know what its called when that happens does anyone??
and i would like to buy a white hood if anyone has a fresh one!!!!!!!!! i already found a front bumper that will fix the cut out for the intercooler
Old Dec 19, 2008 | 09:45 AM
  #27
madsteez's Avatar
Ohhh Snap
Said well,i loved the suspension on it,very solid. All I did to the suspension is both inner and outter tie rods and ends,new front lower control arm bushings,new rear lower control arm bolts,new rear strut top hats,about 4 wheel studs and what ive already listed.
Thats not the original hood.
Old Dec 19, 2008 | 09:55 AM
  #28
cjsass's Avatar
Killa VBeez
well i figured that about the hood....bump for brand new 2000 civic si axles just bought from bap geon and all new 16 wheel studs im installing them now as we speak!!
new tires are tommorrow !!!
Old Dec 19, 2008 | 03:22 PM
  #29
cjsass's Avatar
Killa VBeez
really want another integra da or dc if its a da must be super clean.
Old Dec 19, 2008 | 08:27 PM
  #30
cjsass's Avatar
Killa VBeez
